Old 12-07-2008, 09:34 PM   #1
falcon428
Your Ride: 03 339xi 97 318i M-Tech
Fuel pump relay
I have a 1997 318i with the "M" on the side body moulding. I can't find the fuel pump relay. It is not where the Bentley Manual says it should be. I checked the other relays in the power distribution box in the engine compartment. There are only two that are four prong, and neither ohmed to the fuel pump fuse #18. I suspect the fuel pump is bad, but don't want to put out the cash until I'm sure it is the problem. Any help would be greatly appreciated.
Old 05-20-2009, 11:22 AM   #2
phantomsys
Your Ride: 2000 540i
Just remove the fuel pump plug turn key to start position and test 2 prongs beside each other for power. If no power then start with fuse
Old 05-24-2009, 03:54 PM   #3
falcon428
Smile
Thanks for the reply. I was finally able to find a diagram for my specific car and test the relay. Turns out it was a bad fuel pump so I swapped it out and the car is up and running again.
Help With Fuel pump and no power!!! POS_BMW E36 7 11-27-2009 10:14 PM
BMW E30 320i fuel pump relay location? Joosep E21, E30 3 03-24-2008 05:23 AM
Car won't start No electric to the fuel Pump Nickmtzr E36 11 01-03-2008 12:08 AM
Fuel Pump relay? NewBIMMERfan85 7 Series (E23, E32, E38, E65, E66) 5 04-15-2007 08:33 PM
