Old 12-02-2008, 09:48 PM   #1
x3precious21
Your Ride: 97 318i
Question Some noises & shaking & ...??
i have a 97 318i..i got it in a trade ... trading & used vehicles equals..problems... im not sure what mine is, when i start driving down the road it'll sometimes stay at like 30-40mph and make this weird noise & shakes a bit...it almost sounds like your driving over a bridge that vibrating noise and the little shake you get from it ...im thinking it could be a transmission problem, but could be wrong... when it does that i shift (its an automatic) it into 3rd and back into drive and it drives fine... its really hard to gain speed when this happens also.. if anyone knows anything that may relate to my problem PLEASEEE let me know!
(-was told by a friend it could need a transmission flush??)
THANKS!!
Old 12-03-2008, 08:28 AM   #2
3050rpm
3050rpm's Avatar
From what you describe it doesn't sound suspension or engine related, but (sad to say) the transmission. Check the service records (if there are any) to see what kind of service the transmission has received. Also, check the transmission fluid level, and if there are any leaks of same. Maybe it's just a matter of getting rid of old fluid and replacing with fresh, as well as checking for speed sensor and wiring harness connections (vulnerable if fluid has been leaking on them). Beyond that, it might be the seals are leaking.
Old 12-03-2008, 08:35 AM   #3
motorwerks
Title: Sitting in Time out
Rate My Car: 160 / 337
Your Ride: '97 328i
+1 on checking the tranny fluid. If you don't know when it was changed last, you should really just have the fluid/filter changed anyways.
Old 12-03-2008, 09:37 PM   #4
x3precious21
Your Ride: 97 318i
no service records i went to have it inspected & they filled the tranny fluid..but ill get the fluid & filter done...it didnt pass inspection b/c i need a catalytic converter so im in the process of buying & replacing that...i actually found a direct fit for $300.. thanks for the advice..wish me luck!
Old 12-04-2008, 10:01 AM   #5
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
if it's not that, look at your cats, I know on mine I had a loose catalytic converter heat shield and it kinda sounds like what you are describing
VIEW MOD LIST & PICS
Originally Posted by Gregg
Car Shaking REALLY bad Mercenary(FH) E36 19 05-19-2012 12:24 AM
E46 Shaking & Vibrating HELP!! kentukred Tire, Wheels And Suspension Forum 14 03-17-2008 08:44 PM
Noises At about 3000 rpms talus22 E21, E30 16 07-10-2006 06:19 AM
Suspension noises Dudesky Non BMW General Automotive Discussion 4 03-05-2006 02:04 PM
Clunking Noises When Going Over Bumps! delmarco E36 12 06-02-2005 05:56 PM
