Old 05-31-2005, 11:28 PM   #1
delmarco
delmarco's Avatar
Rate My Car: 228 / 337
Your Ride: 2001 330i
Clunking Noises When Going Over Bumps!
So I'm driving today with the windows down and the music off something I haven't done since Sept 2004 and you'd be surprise how much you hear from your car...
anyway I noticed that everytime I went over bumps there was a "clunking metallic sound" from the under carriage. The best way to describe it is to liken it to 3 or 4 steel pipes in bag that is shaken up and you hear the pipes knocking about....
I'm wondering of this is my bearings, suspensions....but I don't know...I checked my undercarriage and everything is well connected...no lose exhaust pipes or metal stuff dragging...
I also noticed that my brakes were squealing but only when I slowed the car down at high speeds...There was no squeals at low speeds braking and no squeals when I stopped hard and mashed the brakes.
What is this about? Is it the Pads or the Calipers? I just got my brake fluids and oil serviced and changed on 4/27/2005!
Old 06-01-2005, 12:16 AM   #2
Spieluhr
Title: ///M Driven
take a rubber mallet and smack your muffler a couple times. check the exhaust hangers and the muffler itself. In my last car i had a loose piece in my muffler i think because it rattled.
Old 06-01-2005, 12:23 AM   #3
delmarco
delmarco's Avatar
huh?
so its not a bearings, suspension thing huh?
i guess i'll do that...smacking the muffler...thing...and i'll see..
Old 06-01-2005, 12:34 AM   #4
Rate My Car: 183 / 337
i think that would be your shock mounts
Old 06-01-2005, 12:35 AM   #5
oh yeah, btw those are really cheap and a very common problem w/e36
Old 06-01-2005, 02:13 AM   #6
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 313 / 337
Shock mount?where is that located?
.BMW 328
Old 06-01-2005, 09:41 AM   #7
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Here are a few DIYs on replacing shock mounts:
http://www.logun.org/shockmnts.htm
http://home.earthlink.net/~frankie66...ockmounts.html (rear)
Old 06-01-2005, 12:07 PM   #8
delmarco
delmarco's Avatar
thanks Komodo!
Old 06-01-2005, 12:42 PM   #9
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
could just be your boots are worn out
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 06-01-2005, 12:47 PM   #10
mpowerd
or your car is a piece...j/k It's probably rear shock mounts....very easy to replace...
Old 06-01-2005, 07:08 PM   #11
wulley1
I don't really agree with the strut mount. If you've ever been in an e36 when it goes it's more of a solid thud than clanking. I do have a metal clanking noise that fits your description. My friends shop put it up on a lift and thought it was a loose heat sheild. Haven't gotten around to removing the heat shield to find out though.
I'd suggest putting the car up on ramps/jack-stands, and like someone mention above, start tapping around with a rubber hammer.
Old 06-01-2005, 09:48 PM   #12
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
it might be your bushings. check them to see if they are worn.
Old 06-02-2005, 05:56 PM   #13
delmarco
delmarco's Avatar
Thanks...guys but you'll never guess what it was.....
Actually my tire jack was loose in the spare tire well at the back and my emergency hammer was loose as well and I guess they were having a party everytime I drove over bumps so that is were the clanging came from.....
I know I know duh.......
Bimmer Bumps Dudesky BMW General Discussion 11 07-30-2005 11:53 PM
