Old 11-08-2008, 04:15 AM   #1
jimbob
Your Ride: 1994 325i se
alarm reprogramming
hi folks, ive just become the lucky owner of a 325i SE in mint condition. however, i have an unusual alarm. alll the alarms i have seen on this model seem to have 2 or 3 buttons and easy programming instructions at hand. mine is a 1 button fob with no key buttons. my local BMW garage would gladly have a look for £90!. does anyone have any idea how to reprogram this type?. any help would me much appreciated. cheers, James
Old 11-08-2008, 11:40 AM   #2
JohnG
Your Ride: 1993 E36 320i
Hi. I take it you have changed the battery?
If you have the same type of factory fitted alarm as me, (factory fitted with the key on/off on the horn box under the hood) then the alarm fob is hard wired.
Inside mine are tiny jumpers which are configured to match your alarm. When I got a replacement fob 2 years ago it didn't work so I changed the jumpers (requires careful use of a soldering iron) and it worked fine.
There wasn't any need to reprogram the main alarm - it just worked!
Old 11-08-2008, 02:00 PM   #3
jimbob
hi, thanks for the reply. what you have explained sounds exactly what BMW said on the phone. i do have the key on/off switch under the bonnett. sorry for sounding like a total plonka but i have no idea what jumpers are so i can explain to the oldman, who is far more compitent at DIY etc.... thanks once again, James
Old 11-09-2008, 04:53 AM   #4
JohnG
I should have explained it a little better. There are several tracks on the reverse of the printed circuit board which have gaps between them. You need to bridge the appropriate gaps with a small piece of wire (jumper) to match the existing remote.
This is assuming that you have the right wiring in yours to start with!
Old 11-11-2008, 12:48 PM   #5
jimbob
hi, thanks for helping, again. i looked at both fobs and they both appear to be exactly the same on chip board reverse. do you think that i could try and purchase new fob like you did then wire these the same as existing fobs on the hope that both these fobs are knackered. cheers, James
Old 11-14-2008, 02:35 AM   #6
JohnG
If the red led is lighting on both of the fobs when you press the button then they are probably OK . The alarm might have been disconnected by the previous owner though (maybe to install an after market alarm?)- it would be worth checking to see if the unit is connected. The alarm unit is located behind the glove box so to check it you would need to remove it.
I assume that you have checked the fuses?
E38 alarm fault Bigal 7 Series (E23, E32, E38, E65, E66) 0 01-13-2007 08:51 AM
Looking for DIY for 330CiC alarm NaplesTopless BMW OEM Parts Department DIY's & FAQ's 1 10-15-2005 03:01 PM
stock alarm and angel eyes... ivopivo E36 11 08-15-2005 03:51 PM
96-on Alarm Diagram SLMDBMR328 Car Audio and Electronics 1 07-10-2005 05:24 PM
