Old 11-02-2008, 03:17 AM   #1
Dathaeus
Your Ride: 1997 328i w/sports package
New Brake Pads & Rotors
Ok... well I am on a big money crunch now so I need to go with the cheapest sadly... so if I order these two from autohausaz.com:
MDB1369 Mintex
Brake Pad Set; Rear; OE Supplier Compound
1 set per car
$32.75
_____________________________________
34211158936 Balo
Brake Disc/Brake Rotor; Rear Left/Right; Solid 280x10mm
2 per car.
$38.95
(x2 right? so total $80?)
Grand total: $110 [for pads and rotors]
and bring to my mechanic, he should be all set to replace the rears correct?
Thanks guys!
1997 328i w/Sports Package
5 speed manual
120,000 miles
Front: 17" (225)
Rear: 17" (245)
Answerway.com
Old 11-02-2008, 12:40 PM   #2
3050rpm
3050rpm's Avatar
You might need a few incidentals, like clips and springs and such, maybe some pad wear sensors, but you've got the basics. You might want to check on the parking brake drums to see what kind of shape they're in, as well as adjust the parking brake itself.
Old 11-02-2008, 01:38 PM   #3
Dathaeus
Right, I am sure my mech can take care of that.... and u r right, I almost forgot... they told me before its a pain to JUST adjust the p-brake, but while they do this job, I will ask that bec its gotten loose again, makes me feel uneasy on the steep driveways I need to park sometimes.
5 speed manual
120,000 miles
Front: 17" (225)
Rear: 17" (245)
Answerway.com
Need to replace rotors WITH brake pads together? Dathaeus E36 4 09-30-2008 08:32 PM
How to replace 540i front brake pads and rotors Cambridge E12, E28, E34, E39, E60 4 04-15-2006 10:55 PM
mmmm brakes bitcore E36 31 11-16-2005 09:24 PM
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 03:05 PM
Owning Brake Pads (and other work) komodo E36 13 06-18-2005 06:38 PM
