| E36 General discussion and technical help for 1992-1998 3 series cars. |
03-20-2008, 07:36 AM
#1
Your Ride: 1995 325is and 1994 325i
abs light on
Hi everyone, new to the community.
I have a '94 325i with 85000 miles, and the abs light comes on from time to time. When ever I start the car the light is off, but 5 to 30 minutes in to the drive it comes on. Please help.
Thanks.
03-20-2008, 09:35 AM
#2
Title: Sitting in Time out
The first likely cause is that you need to replace the brake fluid.
03-20-2008, 09:39 AM
#3
thanks whiteshark. I will try that
03-21-2008, 09:08 PM
#4
just have the code read...... could be something as simple as a speed sensor or brake position sensor......... too many possibilities to just start changing things
05-10-2008, 03:13 PM
#5
Your Ride: 96 328i convertible
It could be the ABS relay needs changing. Check the simple things first.
05-10-2008, 03:20 PM
#6
Your Ride: '95 ///M3
it could be that the wheel speed sensors that control the abs or something like that is dirty. my abs light has been on for a while, untill we got a huge rain storm a couple days ago. I drove through a bunch of huge puddles and now the light is off. easy fix
05-11-2008, 06:29 AM
#7
Your Ride: E36 1993 325is
i agree with peterkdenny you need to chk the speed sensors and try to clean them and make sure that they are working (if one of them not working all ABS will not respond), and also replace the break oil
05-11-2008, 06:55 AM
#8
Where are these abs sensors located?
05-11-2008, 09:20 PM
#9
i think their just little wires that that connect somewhere on each hub. if you take your wheel off, it should be the only wire there, unless theres also a brake pad sensor wire
05-19-2008, 12:47 AM
#10
Your Ride: 1995 328i
The problem could also be caused from faulty bearings as well as wheel speed sensors. I'm more thinking wheel bearings since it comes on after driving.
05-19-2008, 04:48 AM
#11
Status:
Online
Your Ride: e36 328i se
does your asc light come on too? after driving for a while i get the abs light, and the asc light on together, and neither then work....curiously both work fine when there are no lights illuminated
05-19-2008, 06:51 AM
#12
yes, the asc lignt does come on 2 minutes after the abs light.
