Old 03-18-2008, 07:24 PM   #1
cavalry13
Your Ride: 1993 325is
Headlight Lense
I've been working through a laundry list of things that I want to do to my 1993 BMW 325is and now I've reached the headlights. The headlight lenses have grown warn and I would like to replace them. Do I have to change out the whole headlight or can I just get the lenses, and if so, where do I get them? Any help is greatly appreciated.
Old 03-18-2008, 07:27 PM   #2
Rate My Car: 84 / 337
What happens to the headlight outer lenses is the same as sun faded paint when they are plastic. As with paint, a strong compound can remove the oxidized layers. And also as with paint, prevention by car wax works perfectly, on all plastic lights. If they are very bad, it may be possible to replace just the outer lenses.
Old 03-19-2008, 08:39 AM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
It's only possible to replace the lenses on European headlights. I'll assume you don't have those because they wouldn't oxidize anyway- they're glass.
Old 03-24-2008, 10:52 PM   #4
junkdrawer
junkdrawer's Avatar
you can restore them I do it for a living. they have to besanded down by someone who knows what theyare doing then brought back to smooth then cleaned and polished. they'll look good as new. brand new divit free surface with no oxidation. cant do the fogs though theyre glass. If you were in nashville id do them for you.
1995 325i with motorsport body package
Old 03-24-2008, 10:55 PM   #5
JetBlack328i
JetBlack328i's Avatar
Rate My Car: 77 / 337
Your Ride: 96 328i
you can get replacement lenses at Umnitza; BMP design and I think Bav Auto
2001 Z3 Headlight question Numark318i Lighting 6 03-25-2008 03:44 PM
***PROJECTOR Z install guide version2*** habbie Lighting DIY's 1 02-25-2008 07:22 PM
dj auto headlight assembly install peterkdenny Lighting 4 02-17-2008 10:37 PM
Headlight switch Pin designations???? Shixapatrol E21, E30 0 11-21-2007 02:16 AM
e36 ellipsoids intall guide habbie Lighting 5 09-20-2006 11:53 PM
