Old 03-21-2008, 11:43 PM   #16
foaxaca
foaxaca's Avatar
Your Ride: 1996 328is
Here is another option for bleeding a cooling system. I have never used it on my '96 328is but I have used it successfully on my '94 Maxda RX-7. The funnel comes with two different sized fittings that should fit snugly into just about any radiator or coolant reservoir opening. This helps avoid having hot coolant spilling out if the radiator or reservoir overflow. It is available from many online vendors. I got mine at Tooldesk.com.
http://www.tooldesk.com/products/pro...il.aspx+id+840
Old 06-23-2011, 03:26 AM   #17
waynesworld
Your Ride: 2000 316i se e46
Exclamation
hopefully someone can help me with this problem i have ive just got an e46 316i se 2000 and im having over heating problems with it and now getting gbh of the ear from the wife can someone please help me sorry hi all newbie here not to sure if this is right fourum i do appolagise if not no thermostat is missing the heater matrix has been bypassed the water pump ive just changed to a metal one the old one came out in pieces plastic and metal removed all the bits i could find in the water pump hole top hose leaking slightly only when hot can it be sorted or am i gonna have to get rid of it i realy like the car if it cant be saved could i convert it to diesel and what engine would suite best and easiest fit please many thanx wayne
E39 Overheating jay E12, E28, E34, E39, E60 10 03-04-2008 08:08 AM
1996 320i intermitent cooling prob bmwntac E36 4 10-30-2007 11:21 AM
Brand new cooling system Alpine328i E36 7 07-10-2006 08:32 PM
Cooling system upkeep notop4me E21, E30 4 06-30-2006 09:47 PM
