Old 02-27-2008, 04:50 PM   #1
Yosuf123
Your Ride: 1994 320i
Question 1994 320i Oxygen sensor
Hello
I have a 1994 320i (Canadian Model). My oxygen sensor needs to be replaced because I keep failing the emissions test.
I wanted to know if anyone knows what kind of O2 sensor my car takes (2 wire, 3 wire, etc.).
I have called the American dealers and a few Canadian dealers and they have been no help.
I am looking to purchase after market parts because they are cheaper. If anyone could help me that would be greatly appreciated.
Old 02-28-2008, 12:37 AM   #2
JetBlack328i
JetBlack328i's Avatar
Rate My Car: 77 / 337
Your Ride: 96 328i
I have a 96 328i and the oxygen sensors have two wires you can climb under the car and look at them to tell..
Old 02-28-2008, 03:59 AM   #3
Maxi
Maxi's Avatar
Your Ride: BMW E46 328i 99
Just take a look at the plug of it. and see how many pin there.
good luck,
Maximum Power
Old 02-28-2008, 09:15 AM   #4
H3-2.1
H3-2.1's Avatar
Your Ride: '96 H3 2.1
What is the production date? month/year? automatic or manual transmission?
Cheers,
Engine: 2.1L Hartge conversion, Supersprint ss headers, Hartge exhaust, KV85 wires, Vitesse cf CAI. Drivetrain: ssk, Vitesse adj. clutch stop. Chassis: 18x8.5 Hartge Classics on 225/40/ZR18 Dunlop Direzza DZ101s, Hartge suspension (shocks, springs, sway bars & strut brace), Vitesse rear brace, ATE BBK. Exterior: Hartge front lip, window & hatch spoilers & mirrors, Vitesse cf door pillars, ZKWs, HIDs & much, much more... Performance BMW Magazine feature car March 2003
Old 02-28-2008, 01:10 PM   #5
Danucksjoe
Your Ride: M3 Cab
Originally Posted by Yosuf123 View Post
.....I wanted to know if anyone knows what kind of O2 sensor my car takes (2 wire, 3 wire, etc.). ......
Four wires, pre-cat......but don't bother
If you failed emissions buying an after market one will not help you. O2 sensors like everything else in life are proprietary and carry patents. Although all O2 sensors do the same thing, adjust the air fuel mixture, they all do it slightly different and as such are engine specific. It's true that using a universal one or one that isn't designed for the specific engine WILL NOT trigger the Check Engine Light but it is equally true that it will not adjust the air fuel ratio properly. This is because the Onboard Diagnostics do not check to see if the sensors are the correct ones, (that's the mechanics job) they check to ensure the sensor is not faulting.
Most O2 sensors adjust the mixture by adjusting a voltage span of 1 volt. The computer adjusts the air fuel mixture according to the signal it receives from the O2 sensor to try and produce the 14.7 : 1 stoich mixture. This is where the engine specific comes into play. What voltage to get this mixture is the part that is slightly different for different sensors and is the part that is patent locked.
For example, let's suppose a specific Ford sensor looks and fits a BMW application. This sensor may send a voltage of 4.8 volts when it senses the stoich A/F ratio. The BMW DME is not calibrated for 4.8 volts to achieve the stoich A/F ratio. It may be calibrated to 5.2 volts to achieve it, anything else will either cause the DME to inject too much fuel or not enough fuel causing rich or lean conditions.
Again, this will not trigger the CEL to illuminate since the OBD's role is to check for faults in the sensor. You may think to yourself, "well it's only 1/3 of a volt, it shouldn't be a big deal" Remember, the entire span of the O2 sensor is 1 volt. In this 1 volt span, the car may not run because it is way too rich, or it's way too lean. So 1/3 volt is a big deal.
Aftermarket products cannot be identical to OEM products....they can perform similar actions but not be identical.
If you're from the Lower Mainland BC like I am, then I can save you the work of trial and error and tell you now, ICBC will not pass you if you use anything but the OEM sensor. Emissions level will not be the same. Been there, done that, bought the T-shirt.
After first using a Ford Econoline sensor, I failed. Changed to the Bosch Universal, I failed. Finally caved in and paid the $225 + labour to BMW and I pass. Of course my knowledge on the subject was very limited at the time so I went to an indy shop first who suggested the O2 sensors and finally went to the dealership who explained it better.
Good Luck
Old 02-28-2008, 02:15 PM   #6
Yosuf123
$350 for O2 sensor from dealership
Hey thanks for all the info, my car is a manual (the only way to go). I called the dealership and they said it was $350!! Which at this point in time in my life is a lot because I just had a son 3 months ago and he goes through a ton of diapers.
Plus I live in Washington state now and would have to order the part from Canada.
What to do.....what to do????
Old 02-28-2008, 03:54 PM   #7
Danucksjoe
Your Ride: M3 Cab
If you live in the states now, order an OEM part from Pelican Parts and install it yourself.
http://www.pelicanparts.com/BMW/cata...pg4.htm#item25
Old 02-28-2008, 03:59 PM   #8
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Dude, calm down. Here's what you should do:
1) Find the part on Pelican Parts
2) Call BavAuto (800)535-2002 and get a price match of the BOSCH sensor - BavAuto has 1000x better customer service than Pelican, trust me, I've been down both roads numerous times.
3) Wait for it to come in
4) Jack up car, crawl under
5) Replace O2 sensor, should be a 22mm if I remember correctly
6) Disconnect battery to clear codes, wait, then connect battery
7) Start car, should be no fault codes.
8) There, easy as pie.
Old 02-28-2008, 05:08 PM   #9
Yosuf123
Do 318i and 325i O2 sensors work for 320i?
Hey Thanks for all the help I appreciate it a lot. I'm trying not to seem like a real dumb ass here but I went to pelican parts and they don't have an O2 sensor for 320i, would a 318i or 325i sensor work for my 320i??
Old 02-28-2008, 05:19 PM   #10
Danucksjoe
Your Ride: M3 Cab
realoem.com and have the last 7 digits of your VIN...you'll get the exact part for the car.
SRS/ Airbag light - Seat Occupancy sensor David Mc E36 0 02-16-2008 07:31 PM
lambda sensor pakboys81 E36 6 10-16-2007 06:53 PM
Thoughts on changing O2 sensor Dudesky BMW OEM Parts Department DIY's & FAQ's 3 02-14-2007 08:13 AM
Potential O2 Sensor Problems Rooz E36 15 06-08-2005 09:54 PM
