Old 02-24-2008, 04:37 PM   #1
APE36
APE36's Avatar
Your Ride: 1994 BMW 325i
E36 Washer Fluid issue... :(
Hey,
My wipers work, but when i flick the stick forward to spray the fluid on the windshield, nothing comes out. The fluid in the well goes down though, so i don't know where its going. Perhaps blockage??? im confused. please help, thanks in advance!
///ANTHONY
Old 02-24-2008, 05:16 PM   #2
Rate My Car: 84 / 337
Have you checked the nozzles? Mine were blocked by car wax, I used a pin to clear them out.
Old 02-24-2008, 05:33 PM   #3
3050rpm
3050rpm's Avatar
It's possible the tubing became disconnected from one of the connections, this happened to me, although it only affected one of the nozzles. I had to undo the insulation under the hood to get access, but lo and behold, once I did I found that somehow the tubing became separated, don't know how. Bit of a pain undoing the insulation, tedious but straightforward.
Old 02-24-2008, 07:37 PM   #4
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
If fluid is running through the tubes and your nozzles aren't blocked and still nothing comes out... it could very well be your check valves being stuck closed. They're located under the hood right next to the exit point of the fluid. You could either order new check valves (they're like $4) or just connect it directly. I did the latter.
Old 02-25-2008, 10:51 AM   #5
APE36
APE36's Avatar
Thank you to you all, I will try everything you suggested.
///ANTHONY
DIY: Bleeding BMW Brakes mullethunter3 BMW OEM Parts Department DIY's & FAQ's 15 11-17-2010 03:11 PM
Changed My Power Steering Fluid Numark318i BMW OEM Parts Department DIY's & FAQ's 2 11-01-2007 01:59 AM
E36 Automatic Transmission Fluid Level Check Chris E36 4 09-03-2007 10:42 AM
BMW Windshield Washer fluid Rooz Video and other Multimedia 5 03-08-2006 09:36 PM
