Originally Posted by Numark318i
seeing how its the fuel lines i would assume the ones that are blocked are vacuum type lins for the system. so you might not be getting the full fuel pressure to the engine.
Thanks Mr. Numark318i,
I'll tell you the prob.
I just replaced that hose No.4 and cleaned hose No3. and refix every thing again( Hoses , Air filter, Air mass....).
But when I tryed to start the engine, it wont start! :!: :?: !, Actually it start but the RBM going down to come off. I think that there is something wrong in the ICV. I disconnected the plug and fixed it again. then the car start but with bad idle ( the engine was dancing ).
What I did>>> I take for 10 min driving maby it's need some hit in her head. I taked to the high way until speed 140 for a while. but no thing changed.
the performance was very bad. hesitation and engine dancing.
When I diagnosed it yesterday. I had error in all following sensors
1- Mass air flow sensor.
2- Throtle positon sensor.
4- Idle control valve sensor.
5- O2 sensor.
We cancled all that errors, then make scan for erros again, I got that O2 sensor only keep appearing when scanning.
But I'm sure that not caused by O2 sensor , I think that wrong still caused by Idle control. Because that O2 sensor error is a long problem, I replaced it already before a year but the error still appear!!
Whech let be sure about Idle control. that I taked my car to 2 proffesional mechanicals. the first one when he saw the car dancing, He said that this caused by Idle control ( like what I'm thinking ). the second one said that may caused by many things.
Any way... I'm planing to do a manual check for all sensors. which I think the diagnostic can't catch them. I'll try that soon.I'll start with that Fucking Idle ( sorry for that word, but because I'm gettin crazy of that ) which I think it's the main reason of my problem.
Any Idea.... any one had like this prob and have solved it before.
Thanks,
