Old 02-23-2008, 03:43 PM   #1
ohidontknowanymore
Your Ride: 95 320
window problems
hey everyone
have a problem with my drivers window when you close the door it goes up and down rapidly as if i was opening the door and closing it i feel it is the door closed switch can anyone tell me where i could find this and is it part of the lock
Old 02-23-2008, 05:37 PM   #2
JetBlack328i
JetBlack328i's Avatar
Rate My Car: 77 / 337
Your Ride: 96 328i
you obviously have a coupe, I have a sedan and mine doesnt have that option. I would say that it has to have a sensor next to the door catch/ locking mechanism. not really sure just a guess.
Old 02-23-2008, 07:21 PM   #3
Danucksjoe
Your Ride: M3 Cab
Originally Posted by ohidontknowanymore View Post
hey everyone
the microswitch responsible for venting and sealing the window is located in the striker on the door sill.
Old 02-24-2008, 10:39 AM   #4
ohidontknowanymore
Your Ride: 95 320
thanks guys found it
Old 02-25-2008, 01:09 AM   #5
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
Spray some CRC Switch cleaner lubricant into the door striker/microswitch area first. The re-initialise the venting feature by turning the ignition switch on (dash lights on but engine not running), fully lower the offending window, then fully raise it and hold the switch to raise the window for at least 5 seconds after the window has closed. This procedure worked well on my E36 and I haven't had a second of trouble with it since.
If this is not the problem, take a look at this thread http://www.bimmerfest.com/forums/sho...d.php?t=248787
Is this the infamous window regulator problem? spicytuna E46 3 11-11-2007 12:34 AM
330ci window switch njjeter E46 2 07-21-2007 04:11 PM
Jammed Window RSF5 E46 3 07-17-2007 11:13 AM
Overheating problems! Oh my! digismack E36 24 01-06-2007 11:05 PM
rear blind help zx7rhitch E36 12 05-30-2006 02:11 PM
