Old 02-23-2008, 11:54 AM   #1
joen65
Your Ride: 1996 bmw 318tds
Question question any help
well folks jus a question for use? am thinking of changeing the engine in my 318tds am thinking of a 2.5 or a 3 litre but am not sure of which engine would fit straight in? dose anyone no which one would fit straight in? or has anyone ever done this conversion before??
Old 02-23-2008, 11:35 PM   #2
Danucksjoe
Your Ride: M3 Cab
It's not a straight forward drop and bolt in job despite the same body and chasis. After the engine, there's the electronic conversion. Then there's the new HVAC that has to be outfitted. Finally when the front end is done, the tranny needs to be swapped to get the gear ratios to match the power output of the engine. In between those major items, there's a whack load of little things that needs attention as you go along.
I considered converting m44 to 3.0 once but ended up buying the M3 instead because it was just plain less expensive.
Old 02-24-2008, 03:10 PM   #3
joen65
so dose that mean there is no other engine i can get just to fit straight in without messing wit the wireing loom
Old 02-24-2008, 06:12 PM   #4
Danucksjoe
Your Ride: M3 Cab
unless you drop an identical motor in there, every engine will require messing around with electronics. The more different the motor, the more messing around is invovled.
Old 02-25-2008, 04:29 PM   #5
joen65
ok sounds like a big job i think ill forget about that is there a bigger turbo i can get my yoake is really slow???
528i MPG Question MBP528 E12, E28, E34, E39, E60 0 01-31-2008 02:19 PM
Airplane Flight Question komodo United Off Topic  **FOR MEMBERS ONLY** 105 07-27-2007 09:35 AM
newbie question about angel eyes Eotnak E36 6 12-19-2006 04:39 PM
Dumbest question record JWhite Introductions and Greetings 17 07-21-2006 11:00 AM
Camber specs question JWhite Tire, Wheels And Suspension Forum 3 06-19-2006 05:16 PM
