Old 02-17-2008, 11:07 AM   #1
jayturk99
Your Ride: 1998 323iC
New to Forum NEED HELP
All of the posts have been really helpful in getting to know this car I just purchased. It's a 98 323i convertible. It has a few issues that I am trying to take care of bit by bit. I tried to get emissions done on this vehicle and failed the visual inspection, check engine light does not illuminate. Simple enough, I read the posts on how to remove the instrument cluster to change the bulb, to my surprise there was no bulb. Does this car have a check engine light? The bulb slot is there,could it have been removed by the previous owner. What's the deal with this car? Help please!
Old 02-17-2008, 12:12 PM   #2
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
i think the engine check light should be on ur instrument cluster so replace it , on other hand some times when u unplug the instrument cluster AIR BAG light comes so try to replace it without removing any wire , and to chk ur instrument cluster you can use my last post ,
1. Press the mileage reset button (the ignition key on off position) and hold
2. While pressing the button turn the ignition key to the KL R (next position) and hold the reset button for 5 sec
the test began ,,,,
740i
Old 02-17-2008, 12:41 PM   #3
jayturk99
Thanks for the reply Max, I have already taken the instrument cluster completely out. Befor I did,I turned the key on and the airbag light is on, no big deal, but I did not have a bulb in the check engine slot.
Old 02-17-2008, 01:01 PM   #4
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 248 / 337
Your Ride: 1997 328i
That's what it sounds like, install a bulb, if the check engine light stays on. Pick up a OBDII scanner & check for codes!>>>http://www.jcwhitney.com/autoparts/P...021471/c-10112
Old 02-17-2008, 01:34 PM   #5
max79
max79's Avatar
use the 2 steps i gave u?
740i
Old 02-17-2008, 03:19 PM   #6
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Im guessing if it didn't pass cause the light wasn't showing and there was an issue that the previous owner took it out so you wouldn't see the light, if you replace it I bet your light will come on if that is an issue as you said it was.
Old 02-18-2008, 08:53 AM   #7
jayturk99
I have replaced the check engine light and it works, goes out when I start engine. Now I have more probs, the other lights in the cluster are now not working,including the odometer and oil service. During the cluster test,odometer lights for a few secs. then goes back out. The connections in the back should are correct, blue harness to blue male, white harness to white male and black harness to black male.
Old 02-18-2008, 09:58 AM   #8
jayturk99
At a lost. Since I put the check engine bulb in, In now have no gauges or idiot lights with the exception of the cel and abs. I am not allowed to test the cluster as previously mentioned. Anyone with any ideas????
Old 02-18-2008, 01:46 PM   #9
jayturk99
THanks everyone for your assistance. I took the instrument cluster back out and noticed a bent pin. I straigthened the pin put the cluster back in did the cluster test and voila, I'm cooking with grease. Everything is working perfectly, I'll keep my fingers crossed.
Ever wonder what people are saying on other forums? CAPiTUL United Off Topic  **FOR MEMBERS ONLY** 14 04-14-2007 07:26 AM
Administration and forum sponsors El Supremo Site Feedback 15 05-23-2006 08:25 AM
How many forum members does it take to change a lightbulb? bmwcrazy Comedy Collection
6 11-20-2005 08:31 PM
How many forum members donald1476 Comedy Collection
1 09-17-2005 01:22 PM
What's Going On In Different Car Forums komodo Comedy Collection
8 05-23-2005 12:29 PM
