Old 02-15-2008, 12:39 PM   #1
txitalian
Your Ride: 1997 328is
how to install main belt
main belt snapped on my 1997 328is. I picked up a new one to replace it and several hours later, I still can't get it on. It is routed correctly per the instructions on my bentley manual. If you look at the picture below, this is the drive belt tensioner, which if I use a 16mm socket on the pulley part, I can loosen it, but it only "wobbles" around and I can't get the belt to go over it. Am I missing something simple? I verified that it is indeed the correct size belt, but no luck.
Any help is appreciated!
Old 02-15-2008, 01:31 PM   #2
Rate My Car: 106 / 337
Not sure what you're referring to, but you can either put a socket over the molded nut (black arrow), or pop off the plastic cap (blue arrow) and use an 8mm Allen key on the bolt behind it. Turning either will allow you to slip the belt over the pulley.
Old 02-17-2008, 06:09 PM   #3
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
loosen the tensioner? Sounds like you are turning it the wrong way.
Timing belt - first time was a success! Full report with pics within paluman E21, E30 7 01-07-2008 08:37 PM
Belt and Overheating Help... ecks E36 12 09-10-2007 09:30 PM
Very important, Alarm install, Shark injector, and custom fiberglass lip!? BaLAnCe17 E36 8 08-14-2006 11:39 PM
Help removing A/C belt projal147 E36 2 05-26-2005 04:00 PM
Fan Belt Joey E21, E30 7 04-18-2005 06:38 PM
