Old 02-14-2008, 02:09 PM   #1
junkdrawer
junkdrawer's Avatar
what to look for when buying a e36
looking at an e36 what are the (beware of) things to look for on it. any suggestions
Old 02-14-2008, 02:35 PM   #2
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 248 / 337
Your Ride: 1997 328i
When I bought my e36,the check brake light circuit warning display was on, so I had to replace the brake switch, replaced the struts & shocks, I had a loud banging noise coming from the rear of the car, so I had to replace the rear trailing arm bushings, & the check engine light was on , So I purchased a OBDII SCANNER & found large Emissions Evap.leak in the Evap. expansion tank!!! Also Check to see if the thermostat housing is plastic & replace ,also change the waterpump because of a plastic impeller! But that was about it!!!! The car is pretty much perfect now!!!
Name:	1997 BMW 328I.jpg
Old 02-14-2008, 02:53 PM   #3
JBM BMW E36
JBM BMW E36's Avatar
Name: JBM BMW E36
Your Ride: 1993 BMW 325i
^^ Sounds like that covers a majority of the general look outs. Mine included replacing cooling hoses and thermostat and housing. Also rear shock mounts. My right rear was not in good condition. (ie. not so attatched, lol). There are plenty of threads to look thru as well with images and such of what to look out for. These though that were mentioned are quite common.
Old 02-14-2008, 03:59 PM   #4
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Check out this write up on things to look for by our very own Dudesky:
http://www.unitedbimmer.com/kb-e36-c...faults-faq.php
Old 02-14-2008, 05:10 PM   #5
iamcreepingdeath
iamcreepingdeath's Avatar
Attachment 1021
Attachment 1022
Attachment 1023
"pretty much perfect", that is, until you get your wheels on!
Old 02-14-2008, 05:12 PM   #6
iamcreepingdeath
when i bought mine (the green one below) i replaced the radiator, because the plastic nozzle/mouth thingy that the main upper coolant hose clamped onto had deteriorated.
My car also had this squatting problem, but i fixed it by buying thicker spring seats from turner motorsport, new springs and shocks, and a rear camber adjustment. and that's about it so far.
Buying an ///M Alpine328i M3 30 09-21-2006 02:39 PM
correct title thinking of buying an e36 325 is nreno88 E36 2 01-03-2006 06:21 PM
thinking of buying an e30 325is nreno88 E21, E30 1 01-03-2006 04:03 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
