Old 02-08-2008, 06:20 PM   #1
joen65
Your Ride: 1996 bmw 318tds
Exclamation any help wit problem please
my 318tds is really anoying me now.its losein power at all times i changed the fuel filter and got the turbo checked has anyone else had a problem like this before any help would be great please ??????????????
Old 02-13-2008, 05:09 PM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Anyone have any ideas about this?
As for a stab in the dark, I'll go with water in the gas. Add some Sta-Bil.
Old 02-13-2008, 05:32 PM   #3
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Sorry I'm not familiar with diesels.
Old 02-13-2008, 06:18 PM   #4
Rate My Car: 84 / 337
How about checking the fuel injectors?
Old 02-19-2008, 05:55 PM   #5
joen65
sorry guys i didn get back to use sooner i got new injectors and still have the same problem any other ideas please?
Old 02-20-2008, 11:59 PM   #6
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Try the battery.
Old 02-21-2008, 04:41 PM   #7
joen65
it accuatly could be the battery it is playing up lately every morning i try to start the car the battery gos dead and i have to jump start it ill get a new one and let use no how i get on wit that thanks again folks
Old 02-21-2008, 05:52 PM   #8
gldfshkpr
gldfshkpr's Avatar
How old is the battery? You might try recharging it and testing it before buying a new one.
Peace,
Kirk
Hang up and drive.
Old 02-21-2008, 09:50 PM   #9
JetBlack328i
JetBlack328i's Avatar
Rate My Car: 77 / 337
Your Ride: 96 328i
take the battery to a parts store have them do a load check on it. That will let you know if the battery is good or not
Old 02-23-2008, 11:37 AM   #10
joen65
hi guys got the battery checked and its working fine this problem is really anoying? am thinking off changeing my engine now gona get something bigger like a 3 litre or something dose anyone no wot engine will fit straight in to my 318tds
Old 02-23-2008, 12:54 PM   #11
nick_318is
nick_318is's Avatar
Assuming its the same chasis as the normal 318i, you should be able to fit a number of bmw engines in. I mean if they can shoehorn a v12 into an e30 almost anything is possible.
Old 02-23-2008, 01:17 PM   #12
Exilion
Exilion's Avatar
Your Ride: 1991 325i
Have you checked the basics like glow plugs and cooling systems. Basically for a diesel to work you need your engine block to be warm, which is the job of glow plugs during startup. Also if it's too hot it can actually combust to early and try to force the crankshaft to turn the opposite way. I haven't heard of this in automotive engines but I assume it's possible if it can happen in marine diesels. However I don't think this is likely because you're losing power at startup which would make me lean towards your glow plugs being old. I don't know much specifically about BMW diesels though so maybe they use some other method of warming the engine block. If that isn't the case then just post again unless you're already set on a new engine.
Old 02-23-2008, 05:40 PM   #13
JetBlack328i
Your Ride: 96 328i
what about the fuel...how old is the fuel in the tank? if its old that could be the cause. Or just some pretty crappy diesel fuel could also be the cause.
Old 02-23-2008, 09:59 PM   #14
joen65
i have changed the glow plugs not to long ago i changed the fuel filter today aswell still not running right its really anoying me now if the exhaust was broke could it cause this problem???
Old 02-23-2008, 10:01 PM   #15
An exhaust problem may well be a cause.
325 brake light problem fgmx Lighting 2 02-01-2008 01:52 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
528I gear problem, Please help me guys, plz plz djfactor E12, E28, E34, E39, E60 3 10-22-2006 05:56 PM
