Old 02-07-2008, 10:43 PM   #1
cdmcali
Your Ride: 1994 325 IS
Unhappy Replaced Wheel Bearing twice in 2 years. Why?
I have a 94 325is and have had to replace my wheel bearing in the right rear twice in the past 2 years. The car is not lowered but has 17" m series wheels off a 2003 3 series. Next week will be my third time. Anyone have any idea why this would keep going out? It is getting costly!!
Old 02-07-2008, 11:25 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
are you driving the car very hard?
Check the suspension components in the rear. Maybe you have worn bushings, causing a movement in the rear resulting in the bearing going out?
also is the bearing you are replacing with Oem?
Old 02-08-2008, 10:27 AM   #3
cdmcali
I will have to have my mechanic check on the suspension stuff. Do you have a recomendation on wheel bearing to use. I would assume that my mechanics have been using OEM bearings?
Old 02-08-2008, 01:06 PM   #4
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 127 / 337
Your Ride: '97 328i
I Would Agree That Its Probably Some Sort Of Suspension Component Out Of Whack Causing Extra Stress On The Bearing And Therefore A Shorter Lifespan. I Dont Know If The Offset On Hose Wheels Is Different From Your Stock But Sometimes That Can Cause Stress On Bearing But I Would Think It Would Be The Same All Around No Just In That Corner
Old 02-08-2008, 01:10 PM   #5
cdmcali
Any suggestion on what brand wheel bearing?
Old 02-08-2008, 07:26 PM   #6
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
^Have it replaced with a BMW OEM bearing. They should last for around 5-10 years if not more under normal use. You are either really hammering the car (lots of left turns) or there is something out of whack in the right rear.
Old 02-08-2008, 08:18 PM   #7
Rate My Car: 183 / 337
for this repair, especially because this will be your third time, id eat it up and take it to the dealer, some things with BMWs are just unique, like for a lot of suspension components, you are not supposed to tighten the bolts when the wheels are hanging loose(like on a lift) you are actually supposed to tighten them as if the car was on the ground
Old 02-09-2008, 06:49 AM   #8
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
i recommends u to use the original part from BMW dealer , or Febi brand ? but about my self i prefer the original part .
740i
Old 02-09-2008, 12:37 PM   #9
cdmcali
Thanks guys!
E39 Rear Wheel Bearing torque settings j4yp E12, E28, E34, E39, E60 2 09-13-2007 11:51 PM
Bad Wheel bearing? dinan540 E12, E28, E34, E39, E60 7 09-12-2007 09:58 AM
DIY: E30 Front Wheel Bearing Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 13 02-18-2007 08:48 PM
325xi front wheel bearing replacement LynnFlores M3 5 04-07-2006 04:47 PM
Wheel bearing wulley1 E36 8 04-07-2006 11:00 AM
