E36 General discussion and technical help for 1992-1998 3 series cars.
Old 02-01-2008, 05:36 PM   #1
gldfshkpr
gldfshkpr's Avatar
Getting off Brake Booster
How does the hose come off the brake booster? Do I just pull? I'm running some Sea Foam tomorrow.
Peace,
Kirk
Hang up and drive.
Old 02-01-2008, 09:22 PM   #2
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 90 / 245
Your Ride: '97 328i
when i do sea foam i pull the hose youre talkin about off of the manifold side and use a 2-foot piece of garden hose (fits perfect) and a funnel
Old 02-01-2008, 10:56 PM   #3
gldfshkpr
gldfshkpr's Avatar
Good idea! Oddly enough I have a piece of garden hose laying around. So it fits over the manifold outlet, yes? This is my first time using Sea Foam. Do you use it as preventative maintenance or have you used it to solve issues like rough idle? I'm slowly getting to know my car now, coming up on 3 months of ownership. I've concluded this is a good thing to do. I suspect the engine is dirty. PO did not do this ever and used Penzoil from 62k to 130k
I'll put half in through the manifold, half through the valve cover and one full pint in with 10 gallons of gas. Sound good?
Peace,
Kirk
Hang up and drive.
Old 02-02-2008, 02:05 AM   #4
215BIMMER535
Your Ride: '97 328i
yea the hose should fit right on, my manifold is different than yours but it should be ok. yes its def good to use as both preventative measure and as cleanup and it may straighten out a rough idle, etc. a couple tips though.. if u want to do the job right, use a FULL can into the manifold and it says to let it sit for 15 minutes.. but the longer the better. ill let mine sit for like 4 hours.(1st time i let it sit for 15 minutes and got next to no smoke comin out, meaning it didnt clean very much out. next time i did it for a few hours and holy shit did it smoke) use another FULL can on a FULL tank of gas and if you wanna run it in the crankcase just add it a couple days or a week before you change the oil. also u may need a friend to man the throttle because if u pour it in too fast it'll wanna stall out. good luck and enjoy smokin out the neighborhood haha its really quite a sight
Old 02-02-2008, 02:18 AM   #5
craig
craig's Avatar
Title: Road Kill
altho i cant help you on this topic, its kinda funny how you guys have almost identical cars. i get confused whose who and i have to look at the screen name.
Old 02-02-2008, 09:14 PM   #6
215BIMMER535
Your Ride: '97 328i
ha yea def real close at a glance
vB code is On
633CSi brake booster kits & CSi & CSi A slyhog-22056 6-Series (E3, E24, E63, E64) 9 06-26-2007 03:07 PM
BMW Inspection Rooz BMW General Discussion 21 03-14-2006 02:10 PM
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 03:05 PM
