Old 01-31-2008, 08:50 PM   #1
gldfshkpr
gldfshkpr's Avatar
Question Okay sport's fans, identify this wire.
Since this is my favorite BMW community, I'm giving you guys first shot at it. My car, as most of you know, has been misfiring at idle. While searching for vacuum line breaks I found this on my '97 318i. Center screen, see the wire that goes off on a 45 degree right angle? It's a wire to an electrical plug that leads somewhere directly below the oil filter. I can't reach my hand down there to see if the wires are broken or just the insulation. Does anyone know what this connection is for anyway?
Peace,
Kirk
Hang up and drive.
Old 01-31-2008, 08:58 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
oil pressure sensor?
Old 01-31-2008, 09:29 PM   #3
gldfshkpr
gldfshkpr's Avatar
Sounds logical. Upon further inspection, it appears only the insulation is broken.
Back to the drawing board!
Peace,
Kirk
Hang up and drive.
Old 02-02-2008, 06:39 AM   #4
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Cylinder head coolant temp sensor. You should have one in the back as well.
For a vaccum leak on a 4cylinder, make sure you check the rubber hoses that run along the back of the intake. There should be 2 of them about 3/4 inch round. If they are soft and you can squeeze it and it stays that shape their no good. They are for your crank case vent which they lead to your pcv valve.
Start your engine, spray brake clean at all the air hoses and connections, if your idle increases, youve found your leak.
e36 ellipsoids intall guide habbie Lighting 5 09-20-2006 11:53 PM
Saturday, July 8th | Drive to Leavenworth | Evolution Sports jrhaile Northwest Region 13 07-06-2006 12:56 AM
E36 DOOR PANELS SWITCHED!!!! Teaser Pics/DIY coming soon! delmarco E36 22 06-22-2006 02:03 PM
weird CEL... ivopivo E36 46 03-22-2006 01:22 PM
So I blew another alternator tonight... komodo E36 46 11-28-2005 04:03 PM
