Old 01-31-2008, 01:07 PM   #1
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
Exclamation spring problem
i had notice that the driver side is higher than the other side by 1 inch?
and after i get lowered my car same thing happen ? any body know why?
740i
Old 01-31-2008, 01:27 PM   #2
Rate My Car: 84 / 337
New springs need time to settle, though I dunno why one side would be settled more
Old 01-31-2008, 03:11 PM   #3
gldfshkpr
gldfshkpr's Avatar
That is a normal BMW trait.
Peace,
Kirk
Hang up and drive.
Old 01-31-2008, 03:18 PM   #4
pswirley
Rate My Car: 218 / 337
Your Ride: 93 325i
All E36 are slightly lower or lean towards the passenger side of the vehicle. Weight of the battery and fuel tank are both factors in this, but the primary reason is in the design. BMW engineers were competent enough to compensate for the weight of the driver (assuming most people drive a 3 series without passengers). When driver weight of approximately 150lbs. is factored in the car sits at the same height on both sides.
Old 01-31-2008, 04:03 PM   #5
max79
max79's Avatar
some body told me the same thing ,i thought he was joking but now i belive him thank u guys,,,,
740i
Old 01-31-2008, 04:07 PM   #6
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
lol never would have thought of that
Deus ex machina
E30 325i Touring
Old 01-31-2008, 04:27 PM   #7
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
If it doesn't feel right might want to check the shock on that side. Give that corner of the car a good shove down if the doesn't settle on the up and goes back down again its probably a blown shock (replace in pairs).
Old 02-02-2008, 01:01 PM   #8
JBM BMW E36
JBM BMW E36's Avatar
Name: JBM BMW E36
Your Ride: 1993 BMW 325i
hit it on the money right here!!
Old 02-02-2008, 09:20 PM   #9
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 248 / 337
Your Ride: 1997 328i
max79
When I replaced the stock springs with the H&R sport springs. I found the original left rear coil spring broken @ the last coil! Just something to think about!
p.s. Did you say you lowered your car?
Old 02-02-2008, 09:45 PM   #10
pswirley
Your Ride: 93 325i
That happened to a friend of mine too JohnnyB. I dont think at all this is the problem the OP is having though. What he described of drivers side being 1 inch higher than passenger side is nothing more than good old E36 lean. OP you have nothing to worry about.
Old 02-02-2008, 09:58 PM   #11
johnnybayonne
Maybe your right!!!! I think he said , he lowered his car already!
Old 02-03-2008, 06:56 AM   #12
max79
max79's Avatar
yes indeed
740i
a/c rpm problem Exilion E21, E30 6 09-08-2007 12:25 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
528I gear problem, Please help me guys, plz plz djfactor E12, E28, E34, E39, E60 3 10-22-2006 05:56 PM
