Old 01-27-2008, 07:42 AM   #1
mmw
Your Ride: 1994 325is
Favorite exhaust rust busting technique?
I am trying to drop the exhaust on my 94 325is for a flex disk replacement, and while the nuts on one exhaust flange came off fairly easily (albeit with an impact wrench), the other flange nuts refuse to budge, no matter how long I have the impact wrench hammering away. Of course, this is the rear-most pipe, a bit harder to get at. Yes, I used some lube, it's soaking overnight for another try.
Does anyone have a good technique for getting things like this off without ruining the studs on the manifold? Thanks for any insights you may have.
Old 01-27-2008, 10:35 AM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
I've never encountered a bolt that wouldn't come off without a little WD-40 or Rusteater and some time.
Old 01-27-2008, 10:35 AM   #3
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
I would say try some PB blaster on it and let it soak in, and maybe hit it a few times. Then get a big Breaker bar and go at it if the impact won't do it.
Old 01-27-2008, 10:59 AM   #4
HyeTide
HyeTide's Avatar
Try using heat from a torch to loosen rust, but have a fire extinguisher handy.
Old 01-27-2008, 12:47 PM   #5
nick_318is
nick_318is's Avatar
Also if worst comes to worst get a sawsall, i did when I changed my exhaust out last spring.
Old 01-27-2008, 12:48 PM   #6
mmw
Thanks all, the heat did it.
Noisy Exhaust Maxi E36 8 01-30-2008 01:37 AM
Money Shift Information bimmersunited BMW General Discussion 1 12-23-2007 05:08 PM
Rogue Engineering Ikon exhaust Rooz Video and other Multimedia 1 01-24-2007 03:25 PM
I Pulled the trigger + Vid! Rooz E46 13 01-23-2007 04:32 PM
For Sale: Active Autowerke Gen. III Exhaust E46 M3 His ///M-inence Bmw Cars For Sale/Wanted 1 12-21-2006 04:05 PM
