Old 01-25-2008, 06:40 PM   #16
JBM BMW E36
JBM BMW E36's Avatar
Name: JBM BMW E36
Your Ride: 1993 BMW 325i
Originally Posted by witeshark View Post
Since water sinks in oil, it would have been clearly visible on the bottom of the dipstick.
so in theory i am okay as far as head gasket is concerned? just need to go on with this valve issue and check all hoses im hoping. this is the part of working days that kills. i gotta work on my car thru the night and nevermind the idea of getting sleep. this p.i.t.a. problem will be figured out b4 i rest again. im tired of its existence. lol.
P.S. appreciate your help and posts WHITESHARK
Old 01-25-2008, 08:27 PM   #17
Rate My Car: 84 / 337
Yeah from what I see, it doesn't look like there's water in the oil.
Old 01-26-2008, 02:46 AM   #18
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
so if there is no water inside (u are in safe side ) , the next step is to check all coolant lines (check also the lines connected to the engine ), maybe the lines is not tied or damaged coz of heat,
if the heater is not working that's mean no water go to the heater core then so the heater core is fine , and the valves needs clean and it lines must be checked
ur problem is small don't worry just leaks on pipes , good look
740i
Old 01-27-2008, 08:49 AM   #19
3050rpm
3050rpm's Avatar
If you're centering upon the heater control valve, here's a diagram of what to look for...
Old 01-30-2008, 02:42 PM   #20
JBM BMW E36
Name: JBM BMW E36
Thanks to all who replied. The part to be relaced is the lower valve hose from heater valve that has a block inlet. on the backside of the block between it and the firewall. Part # to the hose is 64211394293. troubles to be concluded and cruises to begin.
Old 01-30-2008, 02:43 PM   #21
JBM BMW E36
Name: JBM BMW E36
In your diagram its the lower hose numbered 4
Old 01-15-2010, 06:52 PM   #22
Anchorsmash
Your Ride: 318 is
Hey JBM how did you finally resolve the problem? I think i have the same problem i have a broken clamp that let go on the hose near the backside of the block near the firewall. It sounds like the same problem you had. i took my car to mechanic and he could see the problem but couldn't get to it. do you know what i need to take apart to get to the hose?
Coolant Leak, Fuck (long post) dinan540 E12, E28, E34, E39, E60 13 03-22-2008 12:25 AM
Overflow Coolant cap on E36 Mercenary(FH) E36 10 04-06-2007 10:31 AM
Tranny Trouble clarkstreet 7 Series (E23, E32, E38, E65, E66) 1 10-04-2006 08:23 PM
Found a used Tranny (long post) dinan540 E12, E28, E34, E39, E60 35 03-21-2006 03:28 PM
Need Auto Tranny Recommendations 1fast325i E36 5 03-09-2006 12:40 AM
