Old 01-20-2008, 07:04 PM   #1
gldfshkpr
gldfshkpr's Avatar
Timing Chain Tensioner
Can a failed timing chain tensioner cause random misfires?
Peace,
Kirk
Hang up and drive.
Old 01-21-2008, 08:51 AM   #2
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
i think failed timming chain means the engine dead
740i
Old 01-21-2008, 09:23 AM   #3
Rate My Car: 84 / 337
Misfires would seem more of an ignition or fuel issue I think.
Old 01-21-2008, 01:30 PM   #4
gldfshkpr
gldfshkpr's Avatar
Right. I'm throwing a P0300 code and I found this info on the net...
A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or coil rubbers
Faulty coils
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
I know my timing chain tensioner is bad and was wondering if that could cause the misfires. Plugs are new, OS Sensors are new. How do I check for a blocked EGR Valve? What are the coils on a BMW? Is that the black box the plugs go into?
Peace,
Kirk
Hang up and drive.
Old 01-21-2008, 01:36 PM   #5
max79
max79's Avatar
so you have to chk the following
spark plug, ignition coils , wires, also the fuel pump, any by the way you have to make sure that the pressure of fuel pump is strong enough coz some times it runs but the pressure is not enough to deliver gasoline. to injectors
740i
Old 01-21-2008, 01:48 PM   #6
max79
max79's Avatar
740i
Old 01-21-2008, 03:00 PM   #7
gldfshkpr
gldfshkpr's Avatar
Originally Posted by max79 View Post
Thanks max. Mine is a bit different with the 4 cylinder engine.
Peace,
Kirk
Hang up and drive.
Replacing timing chain tensioner...need help !!! singring E36 2 05-16-2010 04:23 PM
M44 Timing Chain Tensioner Question singring E36 0 06-01-2006 06:51 PM
How Do You Release Timing Chain Tensioner ?? singring E36 3 05-29-2006 03:15 PM
318i Timing Chain Rattle singring E36 2 05-12-2006 12:34 PM
318i Timing Chain Rattle singring E36 0 05-11-2006 11:14 PM
