Old 01-20-2008, 09:21 AM   #1
EC98328IC
Your Ride: 1998 328ic
Rubbing noise in steering column??..
Has anyone had this problem? Whenever you turn the steering wheel you get a rubbing sound? My mechanic says it could be some sort of spring or ring inside the column. He wants to take the sterring wheel off to get into it. Any other way to get this fixed? Also where or how do I get to the cabin filter? , I'd like to replace it myself, thanks!
Old 01-21-2008, 03:10 PM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
What do you mean by 'rubbing noise'? Like leather rubbing leather, or is it a more serious 'power steering pump grind' sound?
As for the cabin filter, it's pretty simple. Here's Dudesky's DIY: Microfilter DIY
Old 01-21-2008, 03:34 PM   #3
nagolskram
Your Ride: 1994 BMW 325i
i know what you mean my 94 325i does the same thing, but it doesnt really bother me too much. there is prob nothing wrong with it, could just be the sterring wheel rubbing against plastic or something.
94 325i
Old 01-21-2008, 04:18 PM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
my e30 made a rubbing nise after i replaced the steering rack.
turns out i had to lube the bushing/insulator where the collum came into the car. Remove the covering from above you pedals and put some grease where the collum comes into the cabin. Also get under the car and do the same from the other side.
Old 01-22-2008, 03:28 AM   #5
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
i think the plastic rack needs adjustment (behind the steering wheel ).
740i
Old 01-27-2008, 11:42 AM   #6
EC98328IC
It's not leather on leather, although that sounds kind of interesting , but it's something behind the steering wheel itself, not in the column, but where the column and the steering wheel come together. Max 39 might be right, I'll need to get me a skinny torx screwdriver to get the cover of the steering and see what it might be.
Old 01-27-2008, 11:59 AM   #7
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 127 / 337
Your Ride: '97 328i
is it a rubbing or a squeeking?
Old 01-31-2008, 05:31 PM   #8
EC98328IC
It's a squeak, so it's got to be the plastic ring inside the steering wheel...
BMW 330i-Power Steering Pump-Defective Bearing soidog E46 10 11-27-2011 08:18 PM
Changed My Power Steering Fluid Numark318i BMW OEM Parts Department DIY's & FAQ's 2 11-01-2007 01:59 AM
noise when steering jybute BMW OEM Parts Department DIY's & FAQ's 2 05-05-2007 04:39 PM
Steering Rack Q. Numark318i E21, E30 12 02-19-2007 11:56 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 12:05 PM
