Old 01-19-2008, 09:25 PM   #1
ant7188
Your Ride: 1995 BMW
whistling
Hey everyone,
when I first start the engine I hear a whistling from the front of the car and when I close the door I also hear the same thing. after it warms up it stops. I opened the hood and listened and it sounds like its coming from around the alternator. Could it be the pulley? Any suggestions? 95 325is 115k miles
Old 01-19-2008, 09:33 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
Originally Posted by ant7188 View Post
Hey everyone,
it is a sqeak or a whistle.
it might be a vacuum line? unless you think it sounds like a bad belt. If so check them.
also maybe check your alternator? Might be going out and thats the noise?
Old 01-20-2008, 09:49 AM   #3
ant7188
Your Ride: 1995 BMW
I thought it has to something with the belts also but they were recently changed. if the vacum lines were no good the car would not drive as well? It may be the alternator cause when I put my ear close to it it sounds louder than usual.
Thanks for your help
Old 01-21-2008, 12:52 AM   #4
Maxi
Maxi's Avatar
Your Ride: BMW E46 328i 99
that's the same thing with my other car 320i 92, it sounds like that. It seems comming from the alternator. But it charg well, I'm not sure what is that mean. I have this problem sence 3 years.
Numark318i:
any more information about it, and how to check that ?
thanks,
Maximum Power
Old 01-21-2008, 08:20 AM   #5
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
fulty alternator bearing .. maybe,,
740i
Old 01-21-2008, 08:47 AM   #6
ant7188
Your Ride: 1995 BMW
Thats sounds like it could be it because it charges fine but it just makes that whislting noise after sartup then goes away once warm
Whistling at idle... Kistoni E36 17 08-30-2006 11:57 PM
