Old 01-18-2008, 08:23 AM   #1
b1mm3r pauly
Your Ride: '91 e36 318i
318 tickover / start problems
hi people,
i have recently acquired a '91 e36 318i. its pretty tidy but i bought it runs very lumpy and sometimes has start problems that extend as far as not starting.
basically when i turn it on then the engine 'hunts' alot. the revs bounce between 400/450ish to 1000rpm. if i take it for a drive it settles it alot better but it still hunts more than i would expect it to.
also sometimes it wont start at all, ive got spark etc and it cranks over but it just doesnt fire up. if i take all the connectors off the fuel pumps and then put them back on then it starts. it still runs lumpy after this.
ive replaced the small vacuum hoses and have a new formed on the way from gsf that connects the inlet air hose to the, well what i think is the iscv...( the round item with two vacuum outlets next to the dipstick.)
any ideas??????
anyone seen similar problems before?? im just off out to get the vacuum hose and some service items, plugs, leads, fuel filter, air filter etc.
cheers in advance.
pauly
Old 01-18-2008, 08:48 AM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
You might want to consider cleaning your idle control valve, otherwise I would suggest replacing all of the vacuum lines.
Old 01-18-2008, 08:54 AM   #3
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 248 / 337
Your Ride: 1997 328i
Is your check engine light on? Do you have a OBD I scanner? I agree with Nick318iS, also sounds like a faulty fuel pump!
Fuel pump
http://www.autohausaz.com/search/gro...20Air%20System
OBD I
http://www.amazon.com/Equus-3120-Dia...0667696&sr=1-1
Old 01-20-2008, 01:19 PM   #4
b1mm3r pauly
check light is not on.
currently replacing all of the vacuum lines!
if i disconnect the iscv then it ticks over steady at 1200rpm but when i plug it back in it idles for approx 20secs then hunts like a bastard.
would this be down to a faulty fuel pump? or iscv?
will clean out the iscv tmrw and the throttle body. cheers. paul
Old 01-20-2008, 02:56 PM   #5
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
sound like u have onr of two problems
1. faulty fuel pump or
2. 2. air flow meter (oxygen sensor)
740i
Old 01-20-2008, 03:00 PM   #6
b1mm3r pauly
cheers!
going to order up a new fuel pump tmrw and get that swapped over. see what the outcome is. i'l also clean up the iscv and throttle body.
is there any way to clean up the ams??
am i correct in thinking the pump under the passenger side of the rear bench is the priming/ lift pump and the one under the drivers side of the rear bench is the actual fuel pump.
is the fuel level sender built into the main fuel pump or is it seperate on these?
cheers. pauly
Old 01-20-2008, 03:15 PM   #7
max79
max79's Avatar
Originally Posted by b1mm3r pauly View Post
cheers!
cheers. pauly
they are seperate , you can replace only the fuel pump (if u found it alone) , also you can chk this web ..
http://www.pelicanparts.com/bmw/tech...-Fuel-Pump.htm
740i
Old 01-20-2008, 03:21 PM   #8
b1mm3r pauly
cheers bud, where is the fuel level sender as my fuel guage doesnt work either.
cheers
Car Won't Start snumfalzumpa E36 12 08-27-2010 01:10 AM
HELP!!! My car wont start due to immobiliser problems lynton BMW General Discussion 2 11-16-2007 07:33 PM
M42 318 Wont Start. ECU problems? Numark318i E21, E30 3 10-14-2007 03:08 PM
Messing around with a 318 "///M" Rooz Kill Stories 21 10-07-2005 04:08 AM
15 Things to do in Wal-Mart komodo Comedy Collection
4 10-05-2005 11:37 AM
