Old 01-17-2008, 11:31 AM   #1
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
knocking when lasts hift
plz some body help me i hear a knocking noise at last gear shift
i replace flex disk ,gearbox oil and filter also center bearing fine , it happens not allthe times ????? plz help its not so annoying but i dont like it ,
the car is 93 325is
740i
Old 01-18-2008, 12:37 AM   #2
max79
max79's Avatar
i assume no body know why is that ?
740i
Old 01-19-2008, 04:12 AM   #3
max79
max79's Avatar
any ideas? any pre. experiences? plz
740i
Old 01-19-2008, 07:49 AM   #4
f16dude
f16dude's Avatar
Rate My Car: 92 / 337
Your Ride: 1992 e30 convertible
sorry pal, search me if I know. Hang tight. someone will know, its just a matter of time.
Dont you just love those instances where someone is pregnant, or lost a limb... Then you have an excuse to go as fast as you darn well please!
Old 01-19-2008, 04:33 PM   #5
Kistoni
Rate My Car: 239 / 337
Your Ride: 316i '95
Need more info. Is the knocking in the gear box or driveshaft. Knocking or vibration? Under power? At a certain speed?
When u replaced the centre bearing did u push the bracket forward so there is a little tension in the mount? This might vibrate if there is slack in the system.
Plus the drive shaft has to go back together lined up the same way or it will be unbalanced.
What condition are your trany mounts? Often the flex disk breaking is a sighn of worn mounts.
Old 01-20-2008, 05:16 AM   #6
max79
max79's Avatar
i feal the knocking comes from differential side, and its knock once at the last shift means after speed 80 km , trany mounts i will replace them
there is no vibration at all ?
dose i have to change the differential fluid?
740i
knocking noise max79 E36 5 12-30-2007 01:01 PM
Intermitent Knocking from prop or gearbox Niggles E36 16 05-10-2007 04:58 PM
slight knocking sound to rear wheel area saltcoats E46 7 05-25-2006 02:43 PM
