you have to check the differential is it for 320i or 325i first of all and then you have to make sure that the tire size is compatible (205/60 R15) or (205/55 R16) or (205/50 R17),
also check ur gearbox is it for 325i or other bmw model?
but once you drive 120km how do you know that ur driving at 100km? you have some device or you just compare ur speed with another car?
As far as seeing if the tranny and diff are from the 320 or 325, I'd crawl under there and look for some part numbers, find a manual and compare it to what should be under there.
