A 530 engine, N54 has doubble vannos, which the entire front timming cover is a totally different setup then your single vannos block.
Only way is to drop the entire 530 engine in along with trans. It would be cheaper and easier to drop a S50 or 52 in.
ok if i wont to put the 530i whole engine what do i have to change ? gearbox , diff ,ecu .. any thing else?
m52 have no big Difference and also you have to swap ecu
