Old 01-08-2008, 05:53 PM   #1
PaulY1972
Your Ride: E36 328i coupe
Unhappy E36 328i will not start
I was driving my 1995 328i today all was fine, I stopped at trafic lights & rev counter started to hunt up & down a little then as i tried to drive off the car jurked then cut out? the car starts a little then cuts out again, Can anyone give me some advise?
The alarm, battery, & starter are all OK
Old 01-08-2008, 07:01 PM   #2
Rate My Car: 84 / 340
How many miles? May be a fuel pump.
Old 01-08-2008, 07:58 PM   #3
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 122 / 340
Your Ride: '97 328i
fuel pump or clogged fuel line/filter ? just a guess
Old 01-09-2008, 08:05 AM   #4
PaulY1972
Thanks for the info, I think you may be correct as I cannot hear the fuel pump when the ingnition is turned on.
Thanks for your help,
Old 01-09-2008, 10:38 AM   #5
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 252 / 340
Your Ride: 1997 328i
Fuel pump, Autohausaz, Also check with with bavauto there price is higher but they will do a price match if you call them!
http://www.autohausaz.com/search/pro...ump%20Assembly
Old 06-09-2011, 07:45 AM   #6
charles 328i e36
Name: charles 328i e36
Your Ride: bmw 328i e36
Hi im having the same problem with mine.Did you ever sort the problem.
Please help dont know were to start.checked pump is fine.
Old 06-10-2011, 12:27 AM   #7
Manolito
Rate My Car: 337 / 340
On a car that old, if you have fuel pressure to the rail, my next suspect would be the crank position sensor. You are going to have to do some diagnostics to verify whether the injectors are pulsing and the plugs are firing.
Old 06-10-2011, 02:15 AM   #8
charles 328i e36
thanks manolito.i did check the fuel rail no fuel going threw.i also replaced the petrol pump still no fuel.Think it could be the relays.Only thing is id ont know wich one is the pumps relay and they are also saying i should check the dme relay.but who knows wich one it is.thanks for ur help.much apreciated
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 33 08-11-2012 01:00 PM
My '96 BMW E36 328i frank de jonge Bimmer Showroom 8 11-16-2010 07:51 AM
E36 328i vs. S60 T-5 vrulz Bimmer Showroom 87 10-21-2007 04:29 PM
e36 328i coupe probs herbertcab126 E36 8 03-27-2007 12:58 PM
WTB: E36 rear springs for 98 328i ASAP!! ivopivo Bmw Cars For Sale/Wanted 4 10-11-2005 10:46 PM
