Old 01-08-2008, 11:21 AM   #1
Silvercat
Your Ride: 320SE 1994
Blower resistor - again ('93 e36)
Yes I know it's not a new topic. But maybe there is an answer I've missed? Mine is a '93 with A/C not climate control. The pack is a green one made by Behr - and I've replaced it twice. First time the replacement lasted a couple of weeks. The second time it lasted nearly six months and I'm about to replace again. My supplier said he had a new or alternative unit made by Febi - but has changed his mind and sent another Behr unit.
Couple of questions.
1. This is obviously not a unique problem - is there a fix without replacing the fan? It seems as if one or maybe more of the resistors which are switched in on positions other than 4 must be blowing. It has been suggested that the fan might have started drawing too much current - why it should I don't know - seemed to be working just fine.
2. Is there an alternative manufacturer?
Thank you in advance!
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 33 08-11-2012 01:00 PM
93 E36 DME and ground magic panorama E36 12 12-10-2010 03:11 PM
Will this tool work for a 93 e36? xsperf E36 1 03-08-2007 03:02 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
