Old 01-07-2008, 08:22 PM   #1
cavalry13
Your Ride: 1993 325is
Electrical Problem?
Yesterday I drove my 1993 BMW 325is with 204k miles about 170 miles to my sisters house to help her with some sheet rocking. Right as I was arriving in her neighborhood my interior lights and headlamps started to dim and suddenly my check engine light came on. Additionally a warning light which resembles a sprocket around an exclamation mark popped up. The car started running very poorly but I was able to make it to her house and spent the rest of the day working on her house. When I went to leave that night the car was totally dead. After retrieving a new battery the car started up just fine and all the lights went away accept for the battery light which was faintly glowing. I made it about halfway back home when suddenly without warning the check engine light and the sprocket with the exclamation mark popped back on and within about 2 minutes after having pulled off to the side of the road, it wouldn’t start. I sat for about 45 minutes while I waited for a tow truck and out of the blue, the car was able to start right back up. Not knowing what was going on and not wanting to do more damage I just waited for the tow and brought my car home. Prior to this my ABS light has been on for about 2 weeks. Does anyone have any idea what’s going on or has heard of this? Thanks for any help.
Old 01-07-2008, 08:41 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 340
The sprocket light I think is a sign of a transmission issue. Was there any varying speed when these things were happening.
Old 01-07-2008, 08:52 PM   #3
gldfshkpr
gldfshkpr's Avatar
Yep. The exclamation inside the sprocket is for the auto transmission. It should come on briefly after start and go off along with the check engine light.
Peace,
Kirk
Hang up and drive.
Old 01-07-2008, 08:55 PM   #4
gldfshkpr
gldfshkpr's Avatar
From the Owner's book...
Emissions-related systems:
Check Engine Lamp goes out once engine
starts.
If this indicator lamp lights up
during normal vehicle operation, either
continuously or intermittently, this indicates
a fault in one of the emissions related
electronic circuits
. Although the
vehicle remains operational, you should
have the systems checked by a BMW
Retailer at the earliest possible opportunity.
Peace,
Kirk
Hang up and drive.
Old 01-07-2008, 08:58 PM   #5
gldfshkpr
gldfshkpr's Avatar
My other thought is worn out alternator. Is yours original?
Peace,
Kirk
Hang up and drive.
Old 01-08-2008, 01:24 AM   #6
cavalry13
I did notice that right when the warning light came on the car seemed to struggle when I pressed the accelerator. It seemed that if I pressed the accelerator the car actually slowed down. And as far as the alternator goes, I’m pretty sure it’s the original one. I’m thinking I will swap out the alternator and then see what happens from there.
Old 01-08-2008, 01:39 PM   #7
3050rpm
3050rpm's Avatar
My (non-definitive) response is it's the alternator, I had similar symptoms when mine went, and if yours is original, you've gone beyond the average life time of them, I think mine went (on the highway, no less) at around 170,000. Got it rebuilt through a friend of a friend, and installation was a DIY job without too much of a hassle following the Bentley manual.
electrical jybute E36 6 05-10-2010 02:14 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
BMW 320i Gas Problem rOMa E36 5 06-27-2007 02:40 AM
Electrical lighting problem...HELP Originalblend E36 1 06-01-2007 12:18 PM
Just finished clutch repair, now electrical system won't charge? bearcat77070 E36 4 02-26-2007 06:24 PM
