Old 01-05-2008, 04:31 PM   #1
ant7188
Your Ride: 1995 BMW
unknown hose
Hey everyone
I have an 1995 e36 and on the air intake (where the air filter is located) it looks like there are two hoses underneath that connect to an elbow one of them broke off with the plastic still inside. In the hose it looks ike there is coolant in it. The car runs fine and it doesnt overheat. Does anybody know what it does?
Old 01-05-2008, 05:45 PM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
Pics and an arrow would help.
Old 01-05-2008, 07:44 PM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 192 / 340
Sounds like the vaccum line hat runs off your intake boot. Some time soon it should cause a check engine light to come on for unmetered air leak. If you get a pair of needle nose plyers and pull out the old plastic its a cheap part to replace. Just lube it up when your putting it back in.
Old 01-05-2008, 11:01 PM   #4
ant7188
Your Ride: 1995 BMW
Thanks that sounds about rite I just thought it was strange to see a hose with coolant in it connected to the intake will this cause the coolant to leak?
Old 01-06-2008, 08:46 AM   #5
Antiburn
Antiburn's Avatar
If it was going to leak it would have leaked by now. A picture would really help but from your explination it sounds like that vaccume line.
Old 01-06-2008, 11:12 AM   #6
Rate My Car: 106 / 340
The hoses are attached to the intake air temp switch on the airbox. It allows antifreeze to warm the throttle body air via the two hoses during the winter months. The switch is probably in the closed position at the moment, which is why there is no leak. But when it gets real cold, it might open up and your coolant will come out.
Old 01-06-2008, 11:57 AM   #7
ant7188
Your Ride: 1995 BMW
great thanks for your response that si exactly it. Here are the picutures anyway. what is the replacement part for this?
Old 01-07-2008, 02:26 PM   #8
ant7188
Your Ride: 1995 BMW
OK i figured out what it was, it is an auxilary t-stat that is mounted in the air filter housing. its about 40 bucks and easy to replace
Old 01-10-2008, 02:48 PM   #9
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeah, when I got my intake a few years back, mine just hang in the engine compartment, I mean I ziptied them to something thats about it. Some intakes have spots for them to attach to which is nice.
Old 01-14-2008, 01:37 AM   #10
Maxi
Maxi's Avatar
Your Ride: BMW E46 328i 99
Good infromation,,
Thanks,
Maximum Power
Power Steering Hose leak Boxer19 E12, E28, E34, E39, E60 14 06-01-2012 07:04 PM
which hose is this? tx328is E36 4 12-03-2007 11:00 PM
P/S Pressure hose question bimmerdad E12, E28, E34, E39, E60 6 05-01-2007 08:41 PM
Need help with a fuel hose leak Douglas E21, E30 6 04-26-2007 05:26 PM
