Old 12-29-2007, 04:41 PM   #1
MarjanM
Your Ride: E36 1993
E36 320 M52 iddle probem
Hello everyone.
As you can see this is my first post here.
I have E36 M52 engine 320 and have been very pleased with my car for more than 3 years so far.
I have a promlem since last month.
Car is showing variations in rpm while iddle.
I have read all about ICV cleaning and was planning to do that right after the New Year eve.
But since this evening car wont go over 1000 prm no mather what i do.
Can this also be caused by the dirt in the ICV.
Also can someone point me where to look for the ICV (i know is somwhere around the intake manifold).
Thanks for any help.
Marjan
Old 12-29-2007, 08:03 PM   #2
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Whens the last time your plugs were changed? Air filter, gas filter cloged? It could be something simple as that.
Old 12-29-2007, 08:40 PM   #3
Rate My Car: 183 / 337
what is it doing, sputtering? cutting off? maybe your TPS?
Old 12-30-2007, 06:56 AM   #4
MarjanM
Your Ride: E36 1993
It happened during ride. I stoped to wait my friend for a half an hour (while engine running - it is cold out side :-)) and when i tryed to go, it wont.
It runs ok on idle but when i pres the pedal it just bouncing from 600 to 1000 rpm no mather how hard i press it.
Old 12-30-2007, 02:16 PM   #5
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
the rpm gose up and down means the air flow meter is needs to change ( of o2 sensor),
if while driving means the fuel pump prussere is not fine or its relay have problem first change the relay
but iam sure ur fuel pump have the problem
E36 320 Runs badly When Cold lesyoungman E36 9 05-17-2007 05:02 AM
ews help on 320 to 328 e36 conversion desperate 4 help E36 1 04-03-2007 12:08 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
