Old 12-29-2007, 05:22 AM   #1
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
knocking noise
hi guys .. i have 325is auto , i got it 2 month ago and since that i here knock noise under my car when i shift the gear from d to n ... after one month i begin to hear that noise when overdrive ( or shift gear4) is set ( after speed 80 km ) and if you driving the caron speed 120 km for example and remove ur foot from accelerator and accelerate again loud knock sound comes ... plz help ...
Old 12-29-2007, 06:23 AM   #2
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Bad trans mounts, center bearing or diff has excessive play.
Is the knock only once or constant
Old 12-29-2007, 08:50 AM   #3
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
what year is your car? is it an e30?
Deus ex machina
E30 325i Touring
Old 12-29-2007, 11:55 AM   #4
max79
max79's Avatar
thanks for Antiburn and denyo77 for replay ......
only knock once ... but i think if there is any problem with center bearing you will feel vibration that i dont have at all ?... and my car is E36 325is 1993 ...
Old 12-29-2007, 01:56 PM   #5
Antiburn
Antiburn's Avatar
Best thing to start off with is get under there and see if anything is loose, worn or torn.
Hve someone in the back seat and see if they hear it comming from a different place, possibly underneath them.
My e30 if you get on and off it with quick blips while driving you can hear the slack in the diff knocking together, but thats only when you get on/off repedly.
The noise your hearing sounds like the same thing I have, but if your diff isnt grinding or howling I wouldnt really worry about it to much. A car with over 100k miles is going to make some noises.
Old 12-30-2007, 01:01 PM   #6
max79
max79's Avatar
i think the problem with diff mounts coz my diff gose up and down when i shift from d to n or r ... and also the rubber mount that join the shaft with gearbox is damaged but have no lose ????
rear noise, E30, mzbmw325i E21, E30 20 04-07-2010 10:12 AM
Clunking noise underneath Dudesky E12, E28, E34, E39, E60 8 08-10-2007 05:53 PM
noise when steering jybute BMW OEM Parts Department DIY's & FAQ's 2 05-05-2007 04:39 PM
Small noise from under the hood ///Mman721 M3 7 07-12-2006 04:03 PM
loose rattle noise in back Blumfepo E12, E28, E34, E39, E60 2 07-18-2005 08:05 PM
