the control unit i think is the same as the ABS unit, and then you also have to replace the throttle body(and maybe the ECU as well), and then you have change all the ABS sensors on each wheel, then you have to fit the switch
Your Ride: E36 318is
for the sensors as i know is not needed to be replaced! only the ecu and the trottle body! you know anywhere i can find this parts ? ? the installation is not a problem
When and Why? I have the same engine (or very similar) and don't have any of that crap except for abs. I mean no offense, I'm just trying to be the devil's advocate. Usually people want to remove systems like that and not add them so I'm curious.
a lot of people who chose to turbocharge or supercharge their cars need to change the throttle body to an non-ASC throttle body, you may be able to get it from one of them. try www.bimmerforums.com , or try www.car-part.com , or try www.vinesauto.com . as for the ASC, i actually dont mind it, sometimes, when there is a ton of snow on the ground and im trying to go up a hill, it feels really nice because i can just give it a very steady amount of gas and the car will climb up the hill straight, while if the ASC was off it would immediately flip sideways and i wouldnt be able to go anywhere. and if tis really that annoying, there is always a switch that you can turn the ASC off
