Old 12-17-2007, 02:53 PM   #1
ant7188
Your Ride: 1995 BMW
Chirping Noise
Hey Everyone,
Im new to this forum, and I was wondering if you guys can help me out. I have a 1995 325is with 114000 miles. I am getting a really weird noise from the heater. It happens only when I have the heat on and not the AC. It sounds like a high pitch chirping (almost like a bird) It usually happens when I am driving for a little bit (like 15 min) It is definitley when the heat is on cause when I shut it off it stops. It is really annoying! Any Suggestions?
Thanks I appreciate it.
Old 12-17-2007, 03:16 PM   #2
MTurboPower3
MTurboPower3's Avatar
Your Ride: Dont have a car yet
Check if the fan is loose.
Old 12-17-2007, 08:23 PM   #3
ant7188
Your Ride: 1995 BMW
How would I go about doing that, Do I have to take apart the whole dash to get to the fan
? Thanks for the response
Old 12-17-2007, 09:30 PM   #4
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
yeah, its def the fan. in mild cases, it will stop if you change the fan speed.
sorry, dunno how accessible the E36's cabin fan is the fortunate thing is that, aside from the noise it makes, in most cases its fine and will operate for years to come. so actually fixing it probably isnt worth the effort.
Old 12-17-2007, 10:33 PM   #5
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Mine does the same thing, and it has for four years now. Personally, I don't know how to fix it, so I've stopped caring since it causes no real problem.
Old 12-18-2007, 07:28 AM   #6
3050rpm
3050rpm's Avatar
Maybe it really is a bird...
Old 12-18-2007, 04:03 PM   #7
ant7188
Your Ride: 1995 BMW
Thanks everyone for your responses. I was planning on leaving it alone but just thought I see if it was anything to be concerned about and if it was an easy fix.
rear noise, E30, mzbmw325i E21, E30 20 04-07-2010 10:12 AM
'99 323i making noise markg E36 0 11-08-2007 03:48 AM
Clunking noise underneath Dudesky E12, E28, E34, E39, E60 8 08-10-2007 05:53 PM
vanos noise cabrit E36 3 02-17-2006 01:25 PM
loose rattle noise in back Blumfepo E12, E28, E34, E39, E60 2 07-18-2005 08:05 PM
