Old 11-29-2007, 03:20 PM   #1
andyc
Your Ride: 1996 318 touring + 1972 VW bus
Unhappy 1998 cut out when hot 318i m43 HELP !!!!
i have a 1996 318i and have recently had a problem with it cutting out when up to operating temp??? i have replaced coolant temp sensor and repaired a slit in air hose from filter (air flow meter ) to throtle body ,, but the problem still remains i have also noticed that before it cuts out it only runs on 2 cyclinders 2 and 4 .... i have checked no,s 1 and 3 after cut out and spark plugs are soaked in fuel. if i clean and dry them put them back in and let it cool down it starts again runs for approx 5 to 10 mins then splutters and dies again.
please help
Old 11-29-2007, 05:48 PM   #2
Exilion
Exilion's Avatar
Your Ride: 1991 325i
Sounds like worn piston rings or valve guide oil seals.
Old 11-30-2007, 07:58 AM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
Cutting out... as in it dies? That's really odd. Dudesky, your thoughts?
Old 11-30-2007, 04:41 PM   #4
andyc
thanks for the reply i do know a bit about cars / engines as i am also an owner of a 1972 vw bay window bus and have repaired it many times.
but in my experience if the rings or guide seals were screwed it would smoke like a rasta ??????
its just weird think im just gona get blindo and start again tomorow
Old 12-05-2007, 03:04 AM   #5
andyc
ive taken it to a specalist and they have found a fault with the ecu... so £200 later its fixed
