Old 11-19-2007, 12:50 PM   #1
tx328is
Your Ride: 1997 328is
which hose is this?
Alright, after months of my idle getting progressively worse, I believe I pinpointed the problem. Vacuum leak. When I'm driving, I can hear a distinct hissing or sucking sound, almost as if its breathing. Anyhow,With the car idling, I sprayed carb cleaner on the area where I could hear the leak and sure enough, the idle surged. I couldn't get a clear enough picture of where I sprayed it, but I traced the hose and below is a picture where it ends up, It is the hose on the right that connects to the throttle body. Is this in fact a vacuum hose and if so, does anybody have the name or part number?
where it connects to the throttle body
and here is where it connects under the intake
Old 11-19-2007, 01:06 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 125 / 340
Your Ride: ^^
check realoem.com for part number
Old 11-19-2007, 08:08 PM   #3
Rate My Car: 184 / 340
is that for the ICV? or is that the coolant overflow hose into the intake? not sure which one you are pointing to
Old 11-21-2007, 11:11 AM   #4
SHAHAB323IS
SHAHAB323IS's Avatar
Title: Professional Noob
Your Ride: 1998 323is
i'm guessing its the electrical wire that plugs into the throttle position sensor in the throttle body
Old 12-03-2007, 11:00 PM   #5
TECH
Your Ride: Sick cars.
The hoses pictured are coolant hoses. There should be a hose on the bottom of the intake boot, which goes under the intake to the idle valve. I believe there is also a plastic fitting on the intake that likes to crack.
Power Steering Hose leak Boxer19 E12, E28, E34, E39, E60 14 06-01-2012 07:04 PM
ICV Cleaning DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 31 01-23-2011 05:45 PM
P/S Pressure hose question bimmerdad E12, E28, E34, E39, E60 6 05-01-2007 08:41 PM
Need help with a fuel hose leak Douglas E21, E30 6 04-26-2007 05:26 PM
Overheating problems! Oh my! digismack E36 24 01-06-2007 11:05 PM
