Old 11-18-2007, 06:35 AM   #1
Steve L
Your Ride: 318TDS
318tds help please?
Hi people
i have a slightly annoying problem with my car .the heater element(light) on the dash has stopped working and now the plugs which are pretty new have stopped working .im trying to work out which of the relays it could be in the fuse box .i have a haynes manual for this car but i cant find the answers there can any one please help me sort this before i have to pay a machanic
cheers for any replies
Steve
Old 11-18-2007, 01:34 PM   #2
Steve L
Your Ride: 318TDS
Old 11-18-2007, 10:35 PM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
What? It might just be late, but I'm confused.
What is the heater element light on the dash? What are the plugs? Fuses? Spark plugs? And what real problems is this causing with the car? Can you still drive it? Is it just annoying? I think we're going to need some specifics here.
Old 11-18-2007, 11:08 PM   #4
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
+1 that what im sayin. is the light not working or is the heater not workin?
Old 11-18-2007, 11:18 PM   #5
Rate My Car: 84 / 340
His car is a diesel. The plugs are pre-start cylinder heaters called glow plugs. They preheat the cylinders for about 15 seconds or so before engine start. Diesels are compression ignition engines, there are no spark plugs. The dash light probably indicates when glow plugs are done and you can start the engine, as to what relay, I'm not sure (my diesel know how comes from the family boat)
Old 11-18-2007, 11:38 PM   #6
mullethunter3
Ooooohhhh... that makes some more sense now. But what problems could this be causing?
Old 11-19-2007, 12:13 PM   #7
Steve L
Your Ride: 318TDS
i had new heat plugs installed to see if it rectified the problem
still no dash light and the car is killing the battery trying to start it now its gone really cold (the plugs are not working because some thing is wrong )
i went to bmw today and they want £78.50 plus vat just for the relays
its not looking good for my wallet
