Old 11-11-2007, 12:42 PM   #1
AStarps
AStarps's Avatar
Your Ride: 1994 325i
325i Intake sensor?
While recently replacing my stock intake with a cold air intake, I noticed a sensor bolted on to the bottom of the original intake assembly, holding it in place. What exactly does this sensor do?
Old 11-11-2007, 05:14 PM   #2
Rate My Car: 106 / 337
It senses the outside air temp and triggers the flow of antifreeze to warm the air at the throttle body. Hence the two hoses connected to it. Mainly effective in the winter months. But don't disconnect it, or you'll end up with idling issues. Just keep it as close as possible to fresh air.
pre-vanos intake manifold dinan540 E12, E28, E34, E39, E60 3 02-03-2009 08:49 AM
Turbo for 325I? maximk2 E36 9 04-28-2007 09:17 PM
intake question... ivopivo E36 21 11-21-2005 01:44 PM
Potential O2 Sensor Problems Rooz E36 15 06-08-2005 09:54 PM
