Old 11-08-2007, 12:17 PM   #1
volvodefector79
Rate My Car: 304 / 340
Your Ride: 1995 525i
Engine codes - anybody speak "dealer?"
Hey! I'm new and have been asking a lot of questions about my (new to me) '96 328i...
The codes I pulled from my computer (current, not just stored) are P0170 (Fuel Trim, Bank 1), P0173 (Fuel Trim, Bank 2), P1188, and P 1189.
Does anybody know what the last two mean? Apparently, they're BMW codes... I'm trying to track down a more comprehensive repair manual with these, but don't have one yet. Help me if you can! :-)
The symptoms are a searching/surging idle (up and down), which is sometimes rough... which occasionally leads to initial acceleration being a little jerky. Overall power is still good, and fuel economy hasn't taken a dramatic dive yet... but we'll see. Anyhow, if anybody knows about those last two codes, fill me in. Thanks! Have a good one, ladies and gentlemen.
Old 11-08-2007, 01:31 PM   #2
Rate My Car: 106 / 340
1188: Fuel control: Bank 1 Sensor 1
1189: Fuel control: Bank 2 Sensor 1
Here's the BMW-specific list:
http://www.obd-codes.com/trouble_codes/bmw/
Old 12-23-2009, 04:53 PM   #3
ntroisi84
Your Ride: 96 328i
I have recently just purchased a 96 328i. My check light is on and I got the same code,1189. What does this mean though and how do I fix it?
Old 05-19-2010, 11:17 PM   #4
kazamali
Your Ride: 99 M3
This means that the 02 sensor for bank 2 is reporting that the mixture is off and has to "trim" the computer to run richer (or leaner) to get back to a stoichiometric ratio of 14.1:1 Air:Fuel mixture.
A lean condition could be caused by a vacuum leak, bad fuel pump/filter/regulator or malfunctioning MAF. Rich conditions could be a stuck injector or a bad MAF.
What really helps here is getting an OBDII scanner software package that will tell you trim readings at different RPMs so that we know if it's running rich/lean at what part of the power band. This will GREATLY help as the codes, themselves are fairly vague.
Old 05-25-2010, 08:11 PM   #5
ntroisi84
Your Ride: 96 328i
Thank you very much for the response. I recently replaced the intake boot. There was a vacume line attached to the bottom of it, and it was dry rotted off. I havent had the numbers reset and checked again since, but by what you say, it sounds like that was the problem. I will let everyone know. Thanks again.
Nate
325is Turbo Project, Engine upgrades? BmwCrazy325 E36 9 06-15-2011 01:15 PM
Dressing My Engine GreenTourer Detailing and Cleaning 11 10-01-2007 10:28 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Red Check Engine Light browneyedgirl E12, E28, E34, E39, E60 16 03-17-2007 02:50 PM
Search Engine Optimization and Tweaking komodo United Off Topic  **FOR MEMBERS ONLY** 23 04-07-2006 11:12 AM
