Check Engine symbol (gear w/exclamation)???
Hello! This is my first posted question... I thank you in advance for your patience. ;-)
I just purchased a '96 328i - love it! But it came without an owner's manual. There are no indicator lights on, but I want to make sure my "Check Engine" light actually works... The only thing is that before starting, when all the lamps come on as a system check, I do NOT see a "Check Engine" light. I DO see an amber-colored gear symbol light with an exclamation point in the center of the gear. Is that the "check engine" light? I just want to be sure. OK - that's question 1. Here's question 2 (and the reason for question #1). I purchased an OBD-II reader a few days ago and, despite the fact that I do not have any indicator lamps on, it reads a couple of codes: "Fuel trim bank 1" and "Fuel trim bank 2", and it actually indicated that I should have a MIL (malfunction indicator lamp) on... even though NONE of my indicator lamps are staying on after starting her up. The idle is a little rough. It still has adequate power, and cruises smoothly, but the idle in the colder weather is erratic (it was just fine when warmer) - it pitches up and down and initially acceleration is a bit jumpy. I'm thinking that this is the MAF sensor (mass air flow meter). Am I on the right track? That's the only problem I've got with the car right now. Anybody - any ideas based on your knowledge/experience with the 2.8L I6? Let me know when you can - and thanks! |
i think the gear w/the ! is the transmission symbol, you have an automatic transmission? and the thing with the rough idle when its cold, is that when there is cold weather or when the car is cold, very rarely my car does that some times, and i know the MAF would throw a check engine light so i figure thats not it, but i notice it only does that when my lights are on, and the heater is on and sometimes the cd-player, so i assume it has something to do with the alternator putting stress on the engine. i then realized that i do not have a BMW battery(some generic kind i dont remember) and i know its much harder to charge a battery when it is cold outside, and i just have a hunch that the battery is the problem, but since it rarely ever does it i dont want to spend 100+ on a new battery if i dont have to, let us know what happens
Well, if the GEAR symbol with a "!" is for the transmission (yes, I have an automatic transmission) then my check engine light doesn't seem to be working... if there is one. My "check control" light works, which prompts you to read the display on the center console... but I know that's not the same as the "CHECK ENGINE" indicator. It must be burnt out or disconnected... any ideas on a fix for that? Also, the problem does not seem to be voltage related, as the idle is irratic even when lights and stereo (and heat/blower motors) are all off.
BMW NuB questions...
I already cleared the stored codes, and after a couple of driving cycles, I re-tried the scanner (even though the "!" "check engine light" was NOT on) and it gave me the same codes: "fuel trim - bank 1" & "fuel trim - bank 2." It also provided two dealer codes. I'll try the fuel additive/cleaner and premium petrol. Otherwise, if anybody else has ideas to add, feel free. Danke!
Another possibility...
...would be the oxygen sensor(s)...
And yes, you should have a "CHECK ENGINE" light, apart from the "CHECK" light that tells you to look at your multifunction display. Considering the fact that you don't see it, and the problems you're having, I would suspect that the bulb was pulled out or burned out by the previous owner to hide the problems during the sale??? |
dudesky, i think his light isnt actually on, it just stays on for a second before he starts the car.. and about the rough idle, yea even if you dont have accessories on it still puts strain on the alternator if the battery is cold(and possible the cells are corroded or whatnot which cause a loss of efficiency)
Oops, my bad . . I read it wrong :D
| All times are GMT -5. The time now is 06:21 AM. |
