Old 10-29-2007, 12:26 PM   #1
bmwntac
Your Ride: 1996 320iSE
1996 320i intermitent cooling prob
my 320i has run without any probs for over 6 months
then my water pump started to leak which i changed 3 weeks ago but since then it seems to lose water when it feels like it . i have checked water level every couple of days since and it seems ok but twice it has lost all water and i mean all.
can anyone help before i hit it with a big hammer.
Old 10-29-2007, 02:12 PM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Although I would be tempted too, I would go hit it with a hammer.
Does anyone know what could be happening?
Old 10-29-2007, 03:59 PM   #3
Rate My Car: 84 / 337
I'd get the system pressure tested. I bet it leaks under pressure while hot
Old 10-29-2007, 11:27 PM   #4
Kistoni
Rate My Car: 239 / 337
Your Ride: 316i '95
Any puddles underneath? Has it been over heating? Remeber to check the coolant level (mid point on expansion tank) when the engine is cold and it will drop if warm/hot.
Could be any number of the plastic connectors or rubber hoses which can perrish like mine just did.
Do the pressure test but also check the cap as this can also leak.
My thermosat also gave up so you might want to do some preventative maintance on your car since it caused my radiator blow appart at the seams and break the inlet neck.
Happy hunting! Let us know what you find.
Old 10-30-2007, 11:21 AM   #5
bmwntac
cheers for all your advice i will let you know what part is dead.
