Old 10-22-2007, 08:31 PM   #1
asko2807
Your Ride: 1997 328i
Starting problems.
Help. I've got a 1997 328i and recently when I start up the car I have to keep my foot on the pedal, if not it would shut off. Once it's warmed up it runs great. Any ideas?
Old 10-22-2007, 08:37 PM   #2
Skilario
Skilario's Avatar
Your Ride: 1997 328is
check the idler control valve, it gets gunked up with carbon and cant open/close so it wont idle. i cleaned mine out with carborator cleaner and got it so that with a shake of the hand you could feel/hear it move around in there, popped it back in and boom, idled perfect. there are some writeups somewhere around here.
Old 10-22-2007, 08:48 PM   #3
asko2807
Icv
Thanks for the quick response. I will clean it out tomorrow. Will loet you know.
Old 10-22-2007, 08:48 PM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
^^what he said.
Old 10-24-2007, 08:24 AM   #5
asko2807
Hey guys I did what you said and cleaned out the ICV really good. The problem is still there, any other suggestions???
Old 11-02-2007, 09:19 PM   #6
asko2807
Hi, you gave me some advice a couple of week ago concerning my 1997 328i. I cleaned the ICV really good but the problem still exists. The problem actually has gotten worse. The car would continue to shut off until warmed up. Any other ideas??? help!!!
Old 11-02-2007, 09:28 PM   #7
Skilario
Skilario's Avatar
hmmm.. might have something to do with MAF? anyone have any ideas?
Old 11-26-2007, 07:01 AM   #8
gwumpkus
happened to mine lately. check ur Fuel Pressure regulator. mine was faulty, had to fllor it one start, but runs fine otherwise. too many mechanics have conveniently pointed to the MAF... i traced the air supply line.. wasnt convinced. turned out iw as right....
hoe this helps
cheers
michael
Old 11-26-2007, 07:33 AM   #9
3050rpm
3050rpm's Avatar
Just a thought, and I really don't know if this fits the symptoms, but you may have a leaking fuel injector(s).
Old 11-26-2007, 08:43 AM   #10
frankzen
frankzen's Avatar
Had the same problem on my 95 ( matter of fact it's back now the weather is colder) - but it stopped doing that when my alternator died and was replaced. My theory at the time was the ICV is electrical and the voltage to it must have been low. However..ahem...it's started doing it again, but ONLY when the engine is near-cold. When it's cold it starts and idles fine, and when it's hot it starts and idles fine. When it is doing it's thing, the check engine lights comes on...until it decides to idle...then it goes off. The code according to everyone I've talked to indicates a MAF problem...but it had been replaced when I bought the car. (it's been doing it's non-idle thing since I bought it). Very annoying to have to sit in your Bimmer until it decides to idle properly!!
--I belong to too many forums--
-- 1995 318 i --
Old 12-03-2007, 10:55 PM   #11
TECH
Your Ride: Sick cars.
Make sure that the idle valve moves freely. You should be able to shake it and make it move.
Old 12-04-2007, 04:57 AM   #12
Rate My Car: 106 / 337
All this is speculation until you pull the fault codes. If you don't have a code reader, go to your local Autozone and they'll retrieve the OBD II error codes for you. Even if the Check Engine light isn't lit, there'll probably be codes stored there.
Same old problems Misfire E21, E30 1 10-10-2007 05:02 PM
need help with engine starting Reddots89 E36 3 05-04-2007 06:31 AM
MAJOR PROBLEM - Starting Car!!!! HELP!!! projal147 E36 12 09-07-2006 11:18 AM
grandparents want a car. craig United Off Topic  **FOR MEMBERS ONLY** 27 05-23-2006 11:47 PM
