Old 10-21-2007, 02:45 PM   #1
hillsider
hillsider's Avatar
Your Ride: 1995 325iC
E36 - part id help needed ?sensor?
Greetings,
So my 95 325Ci overheated yesterday, turns out it was nearly empty of coolant, due to a broken part. A small solenoid (non-electric) or sensor of some sort. It is located in the lower portion of the air filter box assembly, and has a collant line (approx 3/8") going into and out of it. Inside was a small spring. This small plastic housing was broken, so that the coolant line just emptied to the street! It was easy enough to remove, only 1 screw and two hoseclamps. But I do not know what it is, I figured I would try my luck here with the guru's before hitting the library tomorrow to id the part for ordering. Thanks in advance,
forgive my ignorance,
cheers then,
Hillsider
Old 10-21-2007, 07:01 PM   #2
Rate My Car: 106 / 337
It's a thermostat for heating the air in the throttle housing during the colder months. Try part #13 54 1 730 682.
Old 10-21-2007, 07:14 PM   #3
hillsider
hillsider's Avatar
Thanks Dudesky!
cheers then,
Hillsider
Part # School c1apton BMW OEM Parts Department DIY's & FAQ's 10 09-01-2010 09:50 AM
For Sale Window Regulator E36 Coupe defkon99 Bmw Cars For Sale/Wanted 0 06-18-2006 10:22 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
