Old 05-23-2005, 06:12 PM   #1
donald1476
Title: President
Rate My Car: 110 / 337
turning right
after some hard driving in the backroads i notice a loud rubbing noise. It only makes the noise/vibrates when i make a right turn, i checked around the wheel well and there is some minor rubbing on the bumbers side, or when my wheel turns right. So i applied a white grease to see where on the tire the rubbing was occuring, if at all. turns out that is not what is making the noise. Could it possibly be a wheel bearing?
Old 05-25-2005, 01:23 PM   #2
jrhaile
Rate My Car: 114 / 337
only when making a right turn.. hmm could be a wheel bearing yeah, could be a problem with your control arm or a portion of it (balls joints etc)...does the car shake when breaking or anything?
Old 05-25-2005, 04:57 PM   #3
wulley1
probably not a wheel bearing, those will usually make the noise unless you are turning the oppisite direction of the bad wheel bearing. Ball joint would be more likely.
Old 05-25-2005, 06:58 PM   #4
donald1476
Title: President
well, it seems to have gotten worse..and it isnt just a noise, you can feel it vibrate. no shaking or vibration when braking though.
Old 05-27-2005, 08:10 AM   #5
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
it is definitely the ball joint. if you don't do something soon, you will be driving along and the wheel will snap and your car will hit the ground. Happened to me.
Old 05-27-2005, 07:58 PM   #6
donald1476
Title: President
hmmm, ill check it out thanks
Old 05-28-2005, 09:33 AM   #7
cruzin 323is
if its just a noise.. then its the hub!
edit: misread.. ya.. its a balljoint! but when u get a balljoint, u gotta get the whole control arm too.. it sucks!
