Old 10-17-2007, 05:07 PM   #1
StiffCookie
StiffCookie's Avatar
Your Ride: 1992 320i SE
M50 Manifold
Hi Guys,
I've heard a lot of people are doing M50 Manifolkd Conversions on E36's to get extra power, but will it work on a 320? From what I've read it only seems to be for 95-98 328's. Im Confused
Thanks in advance
Old 10-17-2007, 08:54 PM   #2
Rate My Car: 183 / 337
no, the m50 manifold was used on the 2.8L engines that are OBDII because the OBDII(post 96 cars) have a restricted manifold which cuts down performance in order to improve exhaust emissions or a bunch of other crap, who knows, but cars pre 96 didnt have that problem. with your car, a 320, im not even sure if the block is the same size, but even if it was then you would probably have the same manifold and it wouldnt make a difference
Old 10-18-2007, 05:25 AM   #3
Rate My Car: 106 / 337
It won't make any difference, in fact you could make things worse. The M50 manifolds from the 320i (M50B20) and 325i (M50B25) are indeed different part numbers. There are slight differences; the intake air sensor and brake booster ports are in a different location on the manifold. You could get around that stuff, but the biggest difference is this: while the intake runners look identical, the ports on the cylinder head are slightly smaller on the B20 engine. I've read horror stories about this because the gaskets don't line up properly and you end up with serious vacuum leaks.
Old 10-18-2007, 11:33 AM   #4
StiffCookie
Thanks a lot lads, that's all I needed to know
M50 Manifold Installed (Pics) komodo E36 35 05-04-2011 12:29 PM
M50 Manifold Installed! Tochenzo E36 6 03-06-2006 12:12 AM
M50 Manifold komodo E36 43 05-22-2005 07:31 PM
M50 Manifold xsperf Bmw Cars For Sale/Wanted 11 05-16-2005 10:14 PM
m50 manifold (i have given in once more :( BaLAnCe17 E36 24 05-15-2005 02:27 PM
