I think the fuel consumption for the M42 and the M44 are pretty much the same (I've had both)...if it's the 1895cc M43 you're talking about, I would imagine as a more modern engine, it'll probably return a better mpg. Can't imagine by much though...way lower bhp too...I think it's only about 115 -120bhp as opposed to the M42/M44's 140bhp.
i believe the only difference between the M42 and M43 is that the M43 has a knock sensor, a different intake, and the M44 is the same as the M43 but .2 liters larger?
i think?
M42 is e30
M43 is e36(from 94 on)
M44 is E36 till 9 or something?
i think they are all basically the same as far as gas mileage go.
The M42 and M44 were only used in the 318is...The M43 was available in a 1.6, 1.8 and 1.9 I thought? The 1.8 was used in the 318i E36s and the 1.9 was used in the E46 318i and 318ci.
Your Ride: e36
i was just thinking about changing my M50 engine with vanos on it, to one of these, but ive changed my mind. mine is better thatn the best from these,M44.
I think you mean that it's different...bigger engine, couple more cylinders.
Your Ride: e36
Well, the sound of engine (m44) was different from m50, and this is the most what i disliked in that, i am used to listen to my m50, and i realised that i dont wonna change that! its no matter for me,more cilinders or bigger the engine...coz usually im not driving very fast,thats why i was thinking that m44 would be perfect, but...
